Nook BNRV300 Motherboard Replacement
  1. Nook BNRV300 Motherboard Replacement, Power Button: step 1, image 1 of 3 Nook BNRV300 Motherboard Replacement, Power Button: step 1, image 2 of 3 Nook BNRV300 Motherboard Replacement, Power Button: step 1, image 3 of 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
    Ask FixBot
  2. Nook BNRV300 Motherboard Replacement: step 2, image 1 of 1
    • Using your fingers, take off the power button.
    Ask FixBot
  3. Nook BNRV300 Motherboard Replacement, Back Cover: step 3, image 1 of 3 Nook BNRV300 Motherboard Replacement, Back Cover: step 3, image 2 of 3 Nook BNRV300 Motherboard Replacement, Back Cover: step 3, image 3 of 3
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
    Ask FixBot
  4. Nook BNRV300 Motherboard Replacement: step 4, image 1 of 1
    • Slide the back cover down towards the USB port to release the back cover.
    • The pictures show the case being pried open, but do not do this unless it is necessary.
    Ask FixBot
  5. Nook BNRV300 Motherboard Replacement: step 5, image 1 of 3 Nook BNRV300 Motherboard Replacement: step 5, image 2 of 3 Nook BNRV300 Motherboard Replacement: step 5, image 3 of 3
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
    Ask FixBot
  6. Nook BNRV300 Motherboard Replacement: step 6, image 1 of 2 Nook BNRV300 Motherboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
    Ask FixBot
  7. Nook BNRV300 Motherboard Replacement, Motherboard: step 7, image 1 of 2 Nook BNRV300 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Use an anti-static mat to prevent electric shock from damaging the motherboard and its components. Be careful when using metal tools on your device.
    • Using a T5 Torx screwdriver, remove the eleven 3mm screws.
    Ask FixBot
  8. Nook BNRV300 Motherboard Replacement: step 8, image 1 of 3 Nook BNRV300 Motherboard Replacement: step 8, image 2 of 3 Nook BNRV300 Motherboard Replacement: step 8, image 3 of 3
    • Place the spudger through the loop of the display cable. Lift the tool up, which will unhook the display cable.
    • Do not put force on the motherboard with the spudger. This could damage components on the motherboard.
    • Using your fingers, lift up the display cable.
    Ask FixBot
  9. Nook BNRV300 Motherboard Replacement: step 9, image 1 of 1
    • Using your fingers, gently lift the motherboard from the display.
    Ask FixBot
1 Guide Comment
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 34
All Time: 1,200
