Up to 20% off select tools
Nook BNRV300 Display Replacement
Views: 4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
109
All Time:
4,003
Comments: 13
8 comments on steps, 5 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide describes the replacement of the display for the Nook BNRV300 device. This device is also referred to as the “Nook Simple Touch” by Barnes & Nobles.
Removing the display is required for replacement of a broken, cracked, or damaged display.
If your screen is malfunctioning, check out this troubleshooting guide for screen malfunctions before you open up your device.
Warning: It is important to note that the display is a thin sheet of glass. When using tools to remove the screen, make sure to go slow and use caution. The screen can crack easily and break into small glass shards. Users may want to wear protection for hands and eyes.
    1. Nook BNRV300 Display Replacement, Power Button: step 1, image 1 of 3 Nook BNRV300 Display Replacement, Power Button: step 1, image 2 of 3 Nook BNRV300 Display Replacement, Power Button: step 1, image 3 of 3
      • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
      • Turn the Nook over to find the power button along the back upper edge.
      • Wedge the spudger between the top of the power button and the upper edge of the device.
      • Push the tool down to pry the button up and off.
      Ask FixBot
    2. Nook BNRV300 Display Replacement: step 2, image 1 of 1
      • Using your fingers, take off the power button.
      Ask FixBot
    1. Nook BNRV300 Display Replacement, Back Cover: step 3, image 1 of 3 Nook BNRV300 Display Replacement, Back Cover: step 3, image 2 of 3 Nook BNRV300 Display Replacement, Back Cover: step 3, image 3 of 3
      • Peel off the white sticker that is covering the screw head.
      • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
      Ask FixBot
    2. Nook BNRV300 Display Replacement: step 4, image 1 of 1
      • Slide the back cover down towards the USB port to release the back cover.
      • The pictures show the case being pried open, but do not do this unless it is necessary.
      Ask FixBot
    3. Nook BNRV300 Display Replacement: step 5, image 1 of 3 Nook BNRV300 Display Replacement: step 5, image 2 of 3 Nook BNRV300 Display Replacement: step 5, image 3 of 3
      • Use a spudger or your fingers to gently pry the connector out of the white socket.
      • The back cover is now fully detached.
      Ask FixBot
    4. Nook BNRV300 Display Replacement: step 6, image 1 of 2 Nook BNRV300 Display Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
      Ask FixBot
    1. Nook BNRV300 Display Replacement, Motherboard: step 7, image 1 of 2 Nook BNRV300 Display Replacement, Motherboard: step 7, image 2 of 2
      • Use an anti-static mat to prevent electric shock from damaging the motherboard and its components. Be careful when using metal tools on your device.
      • Using a T5 Torx screwdriver, remove the eleven 3mm screws.
      Ask FixBot
    2. Nook BNRV300 Display Replacement: step 8, image 1 of 3 Nook BNRV300 Display Replacement: step 8, image 2 of 3 Nook BNRV300 Display Replacement: step 8, image 3 of 3
      • Place the spudger through the loop of the display cable. Lift the tool up, which will unhook the display cable.
      • Do not put force on the motherboard with the spudger. This could damage components on the motherboard.
      • Using your fingers, lift up the display cable.
      Ask FixBot
    3. Nook BNRV300 Display Replacement: step 9, image 1 of 1
      • Using your fingers, gently lift the motherboard from the display.
      Ask FixBot
    1. Nook BNRV300 Display Replacement, Display: step 10, image 1 of 3 Nook BNRV300 Display Replacement, Display: step 10, image 2 of 3 Nook BNRV300 Display Replacement, Display: step 10, image 3 of 3
      • Insert a nylon spudger between the display's metal backing and the front cover plastic.
      • Gently pry the display away from the front cover by moving the spudger up and down.
      • During reassembly, align the small black plastic peg at the bottom right of the plastic frame with the inner hole at the bottom right of the metal display backing.
      Ask FixBot
    2. Nook BNRV300 Display Replacement: step 11, image 1 of 2 Nook BNRV300 Display Replacement: step 11, image 2 of 2
      • Press down on the fastener tab with your finger.
      Ask FixBot
    3. Nook BNRV300 Display Replacement: step 12, image 1 of 2 Nook BNRV300 Display Replacement: step 12, image 2 of 2
      • The display cracks very easily. If this happens, there will be glass shards that could potentially cause injury. You may want to wear protection for hands and eyes while completing this step.
      • Insert a nylon spudger between the plastic frame on the display and the metal casing on the display.
      • Gently pry the display away from the plastic frame. Place the display on a hard, flat surface to support it when prying it off the metal backing. The screen may crack anyway.
      Ask FixBot
2 other people completed this guide.
Author
with
Alisyn Waite
417 Reputation
3 Guides authored
5 Guide Comments
Was all good till I got here:
The display was glued to the metal backing. Needs something to heat up the adhesive in order to remove it.
Joseph W Charpentier - Reply Share
Hi. What display model should I look for? Is this one ED060SC7 good?
pogo79 - Reply Share
I'm looking in the Aliexp... store and I don't know what display to choose .
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Reply Share
Appreciate the feedback!
Emily Tracy - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 109
All Time: 4,003
