Nook BNRV300 Battery Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
121
All Time:
5,272
Comments: 9
8 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The battery is one of the most common components in need of replacement. This guide contains instructions for removing the 3.7 V lithium-ion polymer battery in the Nook BNRV300 device. This device is also called the “Nook Simple Touch.”
Without a properly-functioning battery, your Nook will not operate. First try troubleshooting your Nook device using these guides if your Nook does not power on, or your Nook will not hold a charge. If your Nook device still fails to operate properly, then follow this Nook BNRV300 Battery Replacement Guide.
Warning: If the battery is swelling, causing discoloration, or smelling bad, removing it may be dangerous. If you suspect your battery is damaged, see this helpful guide for what to do with a swollen battery.
Tools
    1. Nook BNRV300 Battery Replacement, Power Button: step 1, image 1 of 3 Nook BNRV300 Battery Replacement, Power Button: step 1, image 2 of 3 Nook BNRV300 Battery Replacement, Power Button: step 1, image 3 of 3
      • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
      • Turn the Nook over to find the power button along the back upper edge.
      • Wedge the spudger between the top of the power button and the upper edge of the device.
      • Push the tool down to pry the button up and off.
      Ask FixBot
    2. Nook BNRV300 Battery Replacement: step 2, image 1 of 1
      • Using your fingers, take off the power button.
      Ask FixBot
    1. Nook BNRV300 Battery Replacement, Back Cover: step 3, image 1 of 3 Nook BNRV300 Battery Replacement, Back Cover: step 3, image 2 of 3 Nook BNRV300 Battery Replacement, Back Cover: step 3, image 3 of 3
      • Peel off the white sticker that is covering the screw head.
      • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
      Ask FixBot
    2. Nook BNRV300 Battery Replacement: step 4, image 1 of 1
      • Slide the back cover down towards the USB port to release the back cover.
      • The pictures show the case being pried open, but do not do this unless it is necessary.
      Ask FixBot
    3. Nook BNRV300 Battery Replacement: step 5, image 1 of 3 Nook BNRV300 Battery Replacement: step 5, image 2 of 3 Nook BNRV300 Battery Replacement: step 5, image 3 of 3
      • Use a spudger or your fingers to gently pry the connector out of the white socket.
      • The back cover is now fully detached.
      Ask FixBot
    4. Nook BNRV300 Battery Replacement: step 6, image 1 of 2 Nook BNRV300 Battery Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
      Ask FixBot
    1. Nook BNRV300 Battery Replacement, Battery: step 7, image 1 of 3 Nook BNRV300 Battery Replacement, Battery: step 7, image 2 of 3 Nook BNRV300 Battery Replacement, Battery: step 7, image 3 of 3
      • The battery is located on the inside back cover of the Nook.
      • Do not use metal tools when prying up the battery. This may puncture the battery and cause harm to you and/or your device.
      • Insert a nylon spudger beneath the clear plastic adhesive holding the battery to the back cover.
      • Work around the battery, peeling up all of the adhesive.
      Ask FixBot
    2. Nook BNRV300 Battery Replacement: step 8, image 1 of 2 Nook BNRV300 Battery Replacement: step 8, image 2 of 2
      • Hold on to one of the adhesive tabs and pull up.
      • This will fully remove the battery from its compartment.
      Ask FixBot
5 other people completed this guide.
1 Guide Comment
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 121
All Time: 5,272
