Noma Pedestal Fan Blade Replacement
    1. Noma Pedestal Fan Blade Replacement, Fan Blade: step 1, image 1 of 2 Noma Pedestal Fan Blade Replacement, Fan Blade: step 1, image 2 of 2
      • Undo the clips on the outer edge of the fan.
      • Make sure the fan is disconnected from the power source before starting.
      Ask FixBot
    2. Noma Pedestal Fan Blade Replacement: step 2, image 1 of 2 Noma Pedestal Fan Blade Replacement: step 2, image 2 of 2
      • Gently remove the front piece by pulling it towards the bottom.
      • Don't pull too hard to avoid damaging the clips on the fan.
      Ask FixBot
    3. Noma Pedestal Fan Blade Replacement: step 3, image 1 of 1
      • Turn the cap clockwise and remove it.
      Ask FixBot
    4. Noma Pedestal Fan Blade Replacement: step 4, image 1 of 3 Noma Pedestal Fan Blade Replacement: step 4, image 2 of 3 Noma Pedestal Fan Blade Replacement: step 4, image 3 of 3
      • Lightly pull the faulty blade towards you.
      • Be careful while pulling to not injure yourself.
      Ask FixBot
    5. Noma Pedestal Fan Blade Replacement: step 5, image 1 of 2 Noma Pedestal Fan Blade Replacement: step 5, image 2 of 2
      • Insert the new fan blade onto the screw .
      • Make sure it's pushed all the way back.
      Ask FixBot
    6. Noma Pedestal Fan Blade Replacement: step 6, image 1 of 2 Noma Pedestal Fan Blade Replacement: step 6, image 2 of 2
      • Place the cap on the screw and tighten it by turning counterclockwise.
      Ask FixBot
    7. Noma Pedestal Fan Blade Replacement: step 7, image 1 of 2 Noma Pedestal Fan Blade Replacement: step 7, image 2 of 2
      • After placing the front piece back on, fasten the clips again.
      • Make sure you align the piece to fit perfectly on the top.
      Ask FixBot
This is a relatively easy process and as long as you follow our step-by-step guide it should be easy to fix.
Taha Hashmi
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 77
All Time: 1,300
