Up to 20% off select tools
Nokia XL Dual Sim Battery Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
98
All Time:
3,242
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to bring your Nokia XL Dual Sim back from the dead with a new battery.
    1. Nokia XL Dual Sim Battery Replacement, Replacing the battery: step 1, image 1 of 3 Nokia XL Dual Sim Battery Replacement, Replacing the battery: step 1, image 2 of 3 Nokia XL Dual Sim Battery Replacement, Replacing the battery: step 1, image 3 of 3
      • Shut off the device completely.
      • Separate the back cover from the device by gently prying the opening out at the loose locations.
      • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
      Ask FixBot
    2. Nokia XL Dual Sim Battery Replacement, Battery Removal: step 2, image 1 of 2 Nokia XL Dual Sim Battery Replacement, Battery Removal: step 2, image 2 of 2
      • Once the back cover is removed, the battery will be in plain sight.
      • Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
      Ask FixBot
    3. Nokia XL Dual Sim Battery Replacement: step 3, image 1 of 1
      • You will now take your new battery and insert it into its designated location. Make sure to look at the position the battery was in before you took it out so you don't damage any of it's important parts.
      • Please be aware that your new battery may need to be charged first in order for your device to power back on.
      Ask FixBot
2 other people completed this guide.
Author
with
Shadeed Bilal
231 Reputation
4 Guides authored
USF Tampa, Team 1-4, Brown Fall 2014 Member of USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 98
All Time: 3,242
