Up to 20% off select tools
Nokia X Battery Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
7
Past 7 Days:
21
Past 30 Days:
145
All Time:
5,799
Comments: 0
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 4 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Before replacing the battery, be sure that the battery is not simply without a charge. Plug the phone into an outlet or a computer through a USB connection and see if the phone begins to charge. You won't need any special tools to replace the battery.
    1. Nokia X Battery Replacement, Battery: step 1, image 1 of 1
      • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
      Ask FixBot
    2. Nokia X Battery Replacement: step 2, image 1 of 1
      • To remove the battery, simply use your finger to pry the battery out of its slot.
      Ask FixBot
    3. Nokia X Battery Replacement: step 3, image 1 of 1
      • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
      Ask FixBot
15 other people completed this guide.
Author
with
Avery Dorsey
1,894 Reputation
4 Guides authored
USF Tampa, Team 6-1, Brown Winter 2015 Member of USF Tampa, Team 6-1, Brown Winter 2015
USFT-BROWN-W15S6G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 145
All Time: 5,799
