Up to 20% off select tools
Nokia N900 USB Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
132
All Time:
3,721
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Nokia N900 USB Replacement, USB: step 1, image 1 of 1
      • Turn the phone over so the screen is face down.
      Ask FixBot
    2. Nokia N900 USB Replacement: step 2, image 1 of 2 Nokia N900 USB Replacement: step 2, image 2 of 2
      • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
      Ask FixBot
    3. Nokia N900 USB Replacement: step 3, image 1 of 1
      • Remove the battery by lifting it out of the device.
      Ask FixBot
    4. Nokia N900 USB Replacement: step 4, image 1 of 2 Nokia N900 USB Replacement: step 4, image 2 of 2
      • Remove the two "L-shaped" antennas by unscrewing the following screws:
      • Four screw M1 .4x5.0
      • Two screw RF1 .4x4
      • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
      Ask FixBot
    5. Nokia N900 USB Replacement: step 5, image 1 of 1
      • You will now have two halves of the phone.
      • Grab the half of the phone that has the keyboard on it
      Ask FixBot
    6. Nokia N900 USB Replacement: step 6, image 1 of 1
      • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
      • Place the key pad and cover to the side for the remaining steps.
      Ask FixBot
    7. Nokia N900 USB Replacement: step 7, image 1 of 1
      • Use a blue plastic opening tool lift the motherboard out of the back cover
      Ask FixBot
    8. Nokia N900 USB Replacement: step 8, image 1 of 1
      • Look at the bottom of the motherboard to find the:
      • USB Port
      • Once you've located the USB Port you can search online or call the manufacturer to replace it.
      Ask FixBot
3 other people completed this guide.
Author
with
Troy Posey
358 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 132
All Time: 3,721
