Nokia N900 Slider Assembly Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
96
All Time:
1,428
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Nokia N900 Slider Assembly Replacement, Slider Assembly: step 1, image 1 of 1
      • Turn the phone over so the screen is face down.
      Ask FixBot
    2. Nokia N900 Slider Assembly Replacement: step 2, image 1 of 2 Nokia N900 Slider Assembly Replacement: step 2, image 2 of 2
      • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
      Ask FixBot
    3. Nokia N900 Slider Assembly Replacement: step 3, image 1 of 1
      • Remove the battery by lifting it out of the device.
      Ask FixBot
    4. Nokia N900 Slider Assembly Replacement: step 4, image 1 of 2 Nokia N900 Slider Assembly Replacement: step 4, image 2 of 2
      • Remove the two "L-shaped" antennas by unscrewing the following screws:
      • Four screw M1 .4x5.0
      • Two screw RF1 .4x4
      • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
      Ask FixBot
    5. Nokia N900 Slider Assembly Replacement: step 5, image 1 of 1
      • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
      • To locate the slider, find the "black tape" on the screen half of the phone.
      • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
      • Once you have completed these steps your phone should be able to slide up and down with ease.
      Ask FixBot
Troy Posey
349 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 96
All Time: 1,428
