Nokia N70 Speaker Replacement
  1. Nokia N70 Speaker Replacement, Battery: step 1, image 1 of 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
    Ask FixBot
  2. Nokia N70 Speaker Replacement: step 2, image 1 of 1
    • Remove the battery cover by lifting it away from the phone.
    Ask FixBot
  3. Nokia N70 Speaker Replacement: step 3, image 1 of 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
    Ask FixBot
  4. Nokia N70 Speaker Replacement: step 4, image 1 of 1
    • Remove the battery from the phone.
    Ask FixBot
  5. Nokia N70 Speaker Replacement, Keypad: step 5, image 1 of 3 Nokia N70 Speaker Replacement, Keypad: step 5, image 2 of 3 Nokia N70 Speaker Replacement, Keypad: step 5, image 3 of 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
    Ask FixBot
  6. Nokia N70 Speaker Replacement: step 6, image 1 of 3 Nokia N70 Speaker Replacement: step 6, image 2 of 3 Nokia N70 Speaker Replacement: step 6, image 3 of 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
    Ask FixBot
  7. Nokia N70 Speaker Replacement, Speaker: step 7, image 1 of 2 Nokia N70 Speaker Replacement, Speaker: step 7, image 2 of 2
    • Use the T6 Torx screwdriver to remove the six 15 mm Torx screws.
    Ask FixBot
  8. Nokia N70 Speaker Replacement: step 8, image 1 of 3 Nokia N70 Speaker Replacement: step 8, image 2 of 3 Nokia N70 Speaker Replacement: step 8, image 3 of 3
    • Lift the bottom edge of the front panel at a 45 degree angle.
    • Remove front panel by slowly pulling it away from the phone at a 45 degree angle.
    Ask FixBot
  9. Nokia N70 Speaker Replacement: step 9, image 1 of 3 Nokia N70 Speaker Replacement: step 9, image 2 of 3 Nokia N70 Speaker Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the speaker location located on the back panel of the phone.
    • Using the tweezers place one side of tweezers in the rectangular slot where the speaker is located
    • Slowly lift speaker away from the back panel.
    Ask FixBot
Justin
1,026 Reputation
5 Guides authored
Cal Poly, Team 6-2, Regan Fall 2011 Member of Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 52
All Time: 4,580
