Up to 20% off select tools
Nokia N70 Keypad Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
116
All Time:
4,869
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 25 minutes
Difficulty: Moderate
Tools
    1. Nokia N70 Keypad Replacement, Battery: step 1, image 1 of 1
      • Orient the phone as shown.
      • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
      Ask FixBot
    2. Nokia N70 Keypad Replacement: step 2, image 1 of 1
      • Remove the battery cover by lifting it away from the phone.
      Ask FixBot
    3. Nokia N70 Keypad Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the marked space.
      • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
      Ask FixBot
    4. Nokia N70 Keypad Replacement: step 4, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
    1. Nokia N70 Keypad Replacement, Keypad: step 5, image 1 of 3 Nokia N70 Keypad Replacement, Keypad: step 5, image 2 of 3 Nokia N70 Keypad Replacement, Keypad: step 5, image 3 of 3
      • Insert the plastic opening tool in the marked areas in between the front and back covers.
      • Pry each corner with the plastic opening tool until the front case completely detaches.
      Ask FixBot
    2. Nokia N70 Keypad Replacement: step 6, image 1 of 3 Nokia N70 Keypad Replacement: step 6, image 2 of 3 Nokia N70 Keypad Replacement: step 6, image 3 of 3
      • Orient the phone so that the keypad is facing you.
      • Remove the keypad by lifting it away from the phone.
      Ask FixBot
Author
with
Justin
1,035 Reputation
5 Guides authored
Cal Poly, Team 6-2, Regan Fall 2011 Member of Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Members
60 Guides authored
1 Guide Comment
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
Imamuddin - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 116
All Time: 4,869
