Up to 20% off select tools
Nokia N70 Display Replacement
Views: 10K
View statistics:
Past 24 Hours:
5
Past 7 Days:
32
Past 30 Days:
137
All Time:
10,105
Comments: 1
1 comment on steps.
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 25 minutes
Difficulty: Moderate
Tools
    1. Nokia N70 Display Replacement, Battery: step 1, image 1 of 1
      • Orient the phone as shown.
      • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
      Ask FixBot
    2. Nokia N70 Display Replacement: step 2, image 1 of 1
      • Remove the battery cover by lifting it away from the phone.
      Ask FixBot
    3. Nokia N70 Display Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the marked space.
      • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
      Ask FixBot
    4. Nokia N70 Display Replacement: step 4, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
    1. Nokia N70 Display Replacement, Keypad: step 5, image 1 of 3 Nokia N70 Display Replacement, Keypad: step 5, image 2 of 3 Nokia N70 Display Replacement, Keypad: step 5, image 3 of 3
      • Insert the plastic opening tool in the marked areas in between the front and back covers.
      • Pry each corner with the plastic opening tool until the front case completely detaches.
      Ask FixBot
    2. Nokia N70 Display Replacement: step 6, image 1 of 3 Nokia N70 Display Replacement: step 6, image 2 of 3 Nokia N70 Display Replacement: step 6, image 3 of 3
      • Orient the phone so that the keypad is facing you.
      • Remove the keypad by lifting it away from the phone.
      Ask FixBot
    1. Nokia N70 Display Replacement, Display: step 7, image 1 of 1
      • Using a torx T6 screwdriver remove the six 15 mm torx screws.
      Ask FixBot
    2. Nokia N70 Display Replacement: step 8, image 1 of 2 Nokia N70 Display Replacement: step 8, image 2 of 2
      • Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle.
      Ask FixBot
    3. Nokia N70 Display Replacement: step 9, image 1 of 2 Nokia N70 Display Replacement: step 9, image 2 of 2
      • Lift the bottom of the display circuit board up and locate the ribbon connection located where the two circuit boards intersect.
      • Remove the ribbon connection that connects the two circuit boards.
      Ask FixBot
    4. Nokia N70 Display Replacement: step 10, image 1 of 3 Nokia N70 Display Replacement: step 10, image 2 of 3 Nokia N70 Display Replacement: step 10, image 3 of 3
      • While pulling back each of the clamps marked in the image, lift out each side of the screen independently.
      • Be careful when using the plastic prying tool to not scratch the display.
      Ask FixBot
9 other people completed this guide.
Author
with
Justin
1,035 Reputation
5 Guides authored
Cal Poly, Team 6-2, Regan Fall 2011 Member of Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 137
All Time: 10,105
