Up to 20% off select tools
Nokia N70 Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
130
All Time:
11,920
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Tools
    1. Nokia N70 Battery Replacement, Battery: step 1, image 1 of 1
      • Orient the phone as shown.
      • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
      Ask FixBot
    2. Nokia N70 Battery Replacement: step 2, image 1 of 1
      • Remove the battery cover by lifting it away from the phone.
      Ask FixBot
    3. Nokia N70 Battery Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the marked space.
      • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
      Ask FixBot
    4. Nokia N70 Battery Replacement: step 4, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
5 other people completed this guide.
Author
with
Justin
1,035 Reputation
5 Guides authored
Cal Poly, Team 6-2, Regan Fall 2011 Member of Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Members
60 Guides authored
1 Guide Comment
A recherche batterie et chargeur Nokia N 70,merci.
abd.atif - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 130
All Time: 11,920
