Up to 20% off select tools
Nokia N70 Back Camera Replacement
Views: 9.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
104
All Time:
9,807
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 30 minutes
Difficulty: Moderate
Tools
    1. Nokia N70 Back Camera Replacement, Battery: step 1, image 1 of 1
      • Orient the phone as shown.
      • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
      Ask FixBot
    2. Nokia N70 Back Camera Replacement: step 2, image 1 of 1
      • Remove the battery cover by lifting it away from the phone.
      Ask FixBot
    3. Nokia N70 Back Camera Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the marked space.
      • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
      Ask FixBot
    4. Nokia N70 Back Camera Replacement: step 4, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
    1. Nokia N70 Back Camera Replacement, Keypad: step 5, image 1 of 3 Nokia N70 Back Camera Replacement, Keypad: step 5, image 2 of 3 Nokia N70 Back Camera Replacement, Keypad: step 5, image 3 of 3
      • Insert the plastic opening tool in the marked areas in between the front and back covers.
      • Pry each corner with the plastic opening tool until the front case completely detaches.
      Ask FixBot
    2. Nokia N70 Back Camera Replacement: step 6, image 1 of 3 Nokia N70 Back Camera Replacement: step 6, image 2 of 3 Nokia N70 Back Camera Replacement: step 6, image 3 of 3
      • Orient the phone so that the keypad is facing you.
      • Remove the keypad by lifting it away from the phone.
      Ask FixBot
    1. Nokia N70 Back Camera Replacement, Back Camera: step 7, image 1 of 2 Nokia N70 Back Camera Replacement, Back Camera: step 7, image 2 of 2
      • Using T6 Torx screwdriver remove the six 15 mm torx screws.
      Ask FixBot
    2. Nokia N70 Back Camera Replacement: step 8, image 1 of 3 Nokia N70 Back Camera Replacement: step 8, image 2 of 3 Nokia N70 Back Camera Replacement: step 8, image 3 of 3
      • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
      • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
      Ask FixBot
    3. Nokia N70 Back Camera Replacement: step 9, image 1 of 3 Nokia N70 Back Camera Replacement: step 9, image 2 of 3 Nokia N70 Back Camera Replacement: step 9, image 3 of 3
      • Locate the rear circuit board by flipping over the front panel.
      • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
      • Caution: Be careful when prying camera out of the slot for the connections are fragile.
      Ask FixBot
6 other people completed this guide.
Author
with
Justin
1,035 Reputation
5 Guides authored
Cal Poly, Team 6-2, Regan Fall 2011 Member of Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Members
60 Guides authored
1 Guide Comment
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 104
All Time: 9,807
