Nokia Lumia 930 Vibration Module Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
57
All Time:
735
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
By reading this guide you will have a better understanding of how to disassemble your phone so as to reach the vibration module located directly behind the daughter engine board.
Tools
    1. Nokia Lumia 930 Vibration Module Replacement, Battery: step 1, image 1 of 1
      • Pull the SIM card holder out of the top of the phone using your fingernail.
      Ask FixBot
    2. Nokia Lumia 930 Vibration Module Replacement: step 2, image 1 of 2 Nokia Lumia 930 Vibration Module Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
      Ask FixBot
    3. Nokia Lumia 930 Vibration Module Replacement: step 3, image 1 of 2 Nokia Lumia 930 Vibration Module Replacement: step 3, image 2 of 2
      • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
      Ask FixBot
    4. Nokia Lumia 930 Vibration Module Replacement: step 4, image 1 of 1
      • Remove the 4mm Torx #4 screw that's securing the battery connector.
      Ask FixBot
    5. Nokia Lumia 930 Vibration Module Replacement: step 5, image 1 of 1
      • Use tweezers to remove the battery connector strap.
      Ask FixBot
    6. Nokia Lumia 930 Vibration Module Replacement: step 6, image 1 of 2 Nokia Lumia 930 Vibration Module Replacement: step 6, image 2 of 2
      • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
      Ask FixBot
    7. Nokia Lumia 930 Vibration Module Replacement: step 7, image 1 of 3 Nokia Lumia 930 Vibration Module Replacement: step 7, image 2 of 3 Nokia Lumia 930 Vibration Module Replacement: step 7, image 3 of 3
      • Use the flat end of a spudger to pry the battery cover from the phone's frame.
      Ask FixBot
    8. Nokia Lumia 930 Vibration Module Replacement: step 8, image 1 of 1
      • Pull up on the heat spreader.
      • Be careful not to tear it!
      Ask FixBot
    9. Nokia Lumia 930 Vibration Module Replacement: step 9, image 1 of 1
      • Use the flat end of the spudger to lift up the battery.
      • The battery is glued in place. Pry up carefully, not to damage it.
      • Two flex cables are directly underneath the battery.
      Ask FixBot
    10. Nokia Lumia 930 Vibration Module Replacement: step 10, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
    1. Nokia Lumia 930 Vibration Module Replacement, Motherboard: step 11, image 1 of 2 Nokia Lumia 930 Vibration Module Replacement, Motherboard: step 11, image 2 of 2
      • Use the flat end of a spudger to disconnect the camera connectors.
      • Pull the camera up and out to remove it from the phone.
      Ask FixBot
    2. Nokia Lumia 930 Vibration Module Replacement: step 12, image 1 of 1
      • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
      Ask FixBot
    3. Nokia Lumia 930 Vibration Module Replacement: step 13, image 1 of 3 Nokia Lumia 930 Vibration Module Replacement: step 13, image 2 of 3 Nokia Lumia 930 Vibration Module Replacement: step 13, image 3 of 3
      • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
      • Remove the orange flex cable from the phone.
      Ask FixBot
    4. Nokia Lumia 930 Vibration Module Replacement: step 14, image 1 of 1
      • Repeat the previous step for the black jumper flex cable under the battery.
      Ask FixBot
    5. Nokia Lumia 930 Vibration Module Replacement: step 15, image 1 of 2 Nokia Lumia 930 Vibration Module Replacement: step 15, image 2 of 2
      • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
      • Remove the antenna.
      Ask FixBot
    6. Nokia Lumia 930 Vibration Module Replacement: step 16, image 1 of 1
      Buy
      • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
      • Apply new adhesive when reassembling the phone.
      Ask FixBot
    7. Nokia Lumia 930 Vibration Module Replacement: step 17, image 1 of 3 Nokia Lumia 930 Vibration Module Replacement: step 17, image 2 of 3 Nokia Lumia 930 Vibration Module Replacement: step 17, image 3 of 3
      • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
      Ask FixBot
    1. Nokia Lumia 930 Vibration Module Replacement, Daughterboard: step 18, image 1 of 2 Nokia Lumia 930 Vibration Module Replacement, Daughterboard: step 18, image 2 of 2
      Buy
      • Use the pointed end of the spudger to pry up the daughterboard.
      • Use tweezers to lift the daughterboard out of the phone.
      Ask FixBot
    1. Nokia Lumia 930 Vibration Module Replacement, Vibration Module: step 19, image 1 of 2 Nokia Lumia 930 Vibration Module Replacement, Vibration Module: step 19, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the vibration boot that covers the module.
      Ask FixBot
    2. Nokia Lumia 930 Vibration Module Replacement: step 20, image 1 of 1
      • Use the flat end of the spudger to lift the module off of the adhesive.
      • Be delicate so that you don't break off the rotating piece of the module.
      Ask FixBot
    3. Nokia Lumia 930 Vibration Module Replacement: step 21, image 1 of 2 Nokia Lumia 930 Vibration Module Replacement: step 21, image 2 of 2
      • Use tweezers to continually lift the module and flex up off of the adhesive.
      • Pull up until the vibration module is completely removed.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 57
All Time: 735
