Nokia Lumia 930 Battery Replacement
    1. Nokia Lumia 930 Battery Replacement, Battery: step 1, image 1 of 1
      • Pull the SIM card holder out of the top of the phone using your fingernail.
      Ask FixBot
    2. Nokia Lumia 930 Battery Replacement: step 2, image 1 of 2 Nokia Lumia 930 Battery Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
      Ask FixBot
    3. Nokia Lumia 930 Battery Replacement: step 3, image 1 of 2 Nokia Lumia 930 Battery Replacement: step 3, image 2 of 2
      • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
      Ask FixBot
    4. Nokia Lumia 930 Battery Replacement: step 4, image 1 of 1
      • Remove the 4mm Torx #4 screw that's securing the battery connector.
      Ask FixBot
    5. Nokia Lumia 930 Battery Replacement: step 5, image 1 of 1
      • Use tweezers to remove the battery connector strap.
      Ask FixBot
    6. Nokia Lumia 930 Battery Replacement: step 6, image 1 of 2 Nokia Lumia 930 Battery Replacement: step 6, image 2 of 2
      • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
      Ask FixBot
    7. Nokia Lumia 930 Battery Replacement: step 7, image 1 of 3 Nokia Lumia 930 Battery Replacement: step 7, image 2 of 3 Nokia Lumia 930 Battery Replacement: step 7, image 3 of 3
      • Use the flat end of a spudger to pry the battery cover from the phone's frame.
      Ask FixBot
    8. Nokia Lumia 930 Battery Replacement: step 8, image 1 of 1
      • Pull up on the heat spreader.
      • Be careful not to tear it!
      Ask FixBot
    9. Nokia Lumia 930 Battery Replacement: step 9, image 1 of 1
      • Use the flat end of the spudger to lift up the battery.
      • The battery is glued in place. Pry up carefully, not to damage it.
      • Two flex cables are directly underneath the battery.
      Ask FixBot
    10. Nokia Lumia 930 Battery Replacement: step 10, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 86
All Time: 6,982
