Nokia Lumia 925 Front Camera Replacement
    1. Nokia Lumia 925 Front Camera Replacement, Motherboard: step 1, image 1 of 2 Nokia Lumia 925 Front Camera Replacement, Motherboard: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
      • Pull out the holder until it is completely separate.
      • Something like a paperclip will work if there are no tweezers available.
      Ask FixBot
    2. Nokia Lumia 925 Front Camera Replacement: step 2, image 1 of 3 Nokia Lumia 925 Front Camera Replacement: step 2, image 2 of 3 Nokia Lumia 925 Front Camera Replacement: step 2, image 3 of 3
      • Slide a plastic opening tool under the back cover.
      • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
      • Some pins are facing the opposite way from the others.
      Ask FixBot
    3. Nokia Lumia 925 Front Camera Replacement: step 3, image 1 of 3 Nokia Lumia 925 Front Camera Replacement: step 3, image 2 of 3 Nokia Lumia 925 Front Camera Replacement: step 3, image 3 of 3
      • Remove the 3 screws using the T7 Torx screwdriver.
      • Unclip the black tab connector.
      Ask FixBot
    4. Nokia Lumia 925 Front Camera Replacement: step 4, image 1 of 2 Nokia Lumia 925 Front Camera Replacement: step 4, image 2 of 2
      • Remove the silver metal cover.
      • Be careful of the tape under the right square side of the panel. Using a spudger helps.
      Ask FixBot
    5. Nokia Lumia 925 Front Camera Replacement: step 5, image 1 of 3 Nokia Lumia 925 Front Camera Replacement: step 5, image 2 of 3 Nokia Lumia 925 Front Camera Replacement: step 5, image 3 of 3
      • Unclip the two orange tabs.
      • Remove the four silver screws using the T5 Torx screwdriver.
      Ask FixBot
    6. Nokia Lumia 925 Front Camera Replacement: step 6, image 1 of 2 Nokia Lumia 925 Front Camera Replacement: step 6, image 2 of 2
      • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
      Ask FixBot
    1. Nokia Lumia 925 Front Camera Replacement, Display: step 7, image 1 of 2 Nokia Lumia 925 Front Camera Replacement, Display: step 7, image 2 of 2
      • Push the screen from the inside of the phone.
      • Pull the screen off.
      • Slide the electronic strip through the small opening.
      Ask FixBot
    1. Nokia Lumia 925 Front Camera Replacement, Speaker: step 8, image 1 of 1
      Buy
      • Locate the grey speaker/camera cover.
      • Carefully remove the cover with either a pair of tweezers or your fingers.
      Ask FixBot
    2. Nokia Lumia 925 Front Camera Replacement: step 9, image 1 of 3 Nokia Lumia 925 Front Camera Replacement: step 9, image 2 of 3 Nokia Lumia 925 Front Camera Replacement: step 9, image 3 of 3
      • With a pair of tweezers, gently remove the orange colored tab closest to the speaker.
      Ask FixBot
    1. Nokia Lumia 925 Front Camera Replacement, Front Camera: step 10, image 1 of 1
      • Pull at the orange section until it becomes loose.
      • It is located in the upper leftmost section of the phone behind the front camera.
      Ask FixBot
    2. Nokia Lumia 925 Front Camera Replacement: step 11, image 1 of 1
      • Pull vertically on the same orange section until the front camera comes out.
      • The front camera as well as the speaker may come out after the last step so be careful.
      Ask FixBot
O'Ryan Lacour
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 564
