Nokia Lumia 900 Front Camera Replacement
    1. Nokia Lumia 900 Front Camera Replacement, Screen: step 1, image 1 of 2 Nokia Lumia 900 Front Camera Replacement, Screen: step 1, image 2 of 2
      • Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
      Ask FixBot
    2. Nokia Lumia 900 Front Camera Replacement: step 2, image 1 of 2 Nokia Lumia 900 Front Camera Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the small rod in the port indicated in the picture.
      Ask FixBot
    3. Nokia Lumia 900 Front Camera Replacement: step 3, image 1 of 2 Nokia Lumia 900 Front Camera Replacement: step 3, image 2 of 2
      • Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
      Ask FixBot
    4. Nokia Lumia 900 Front Camera Replacement: step 4, image 1 of 2 Nokia Lumia 900 Front Camera Replacement: step 4, image 2 of 2
      • Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
      Ask FixBot
    5. Nokia Lumia 900 Front Camera Replacement: step 5, image 1 of 1
      • Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
      • Remove the screen.
      Ask FixBot
    1. Nokia Lumia 900 Front Camera Replacement, Front Camera: step 6, image 1 of 2 Nokia Lumia 900 Front Camera Replacement, Front Camera: step 6, image 2 of 2
      • Use the iFixit iOpener or another heat source to gently heat the top left corner until the adhesive under the camera softens.
      • Use the plastic opening tools to carefully lift the front camera from the motherboard.
      Ask FixBot
Kourtney Collier
289 Reputation
3 Guides authored
IUPUI, Team 3-2, Harley Spring 2022 Member of IUPUI, Team 3-2, Harley Spring 2022
IUPUI-HARLEY-S22S3G2
3 Members
35 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 23
All Time: 379
