Nokia Lumia 900 Battery Replacement
  1. Nokia Lumia 900 Battery Replacement, Opening The Phone: step 1, image 1 of 2 Nokia Lumia 900 Battery Replacement, Opening The Phone: step 1, image 2 of 2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Battery Replacement, Remove Old Battery: step 2, image 1 of 1
    • Detach connector A from the phone.
    • Use the opening tool to pry out battery from the phone.
    • The battery should come out fairly easily
  3. Nokia Lumia 900 Battery Replacement, Installing New Battery: step 3, image 1 of 1
    • Place the battery in the empty battery slot
    • Attach connector A to the battery terminal.
  4. Nokia Lumia 900 Battery Replacement, Reassembling The Screen: step 4, image 1 of 1
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Finish Line
2 other people completed this guide.
Joshua Crosman
304 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 32
All Time: 3,147
