Nokia Lumia 830 Battery Replacement
    1. Nokia Lumia 830 Battery Replacement, Battery: step 1, image 1 of 2 Nokia Lumia 830 Battery Replacement, Battery: step 1, image 2 of 2
      • Place the phone with the screen facing down.
      • Remove the back cover by placing your fingernail or plastic opening tool under the slotted indent at the bottom of the phone.
      Ask FixBot
    2. Nokia Lumia 830 Battery Replacement: step 2, image 1 of 3 Nokia Lumia 830 Battery Replacement: step 2, image 2 of 3 Nokia Lumia 830 Battery Replacement: step 2, image 3 of 3
      • Carefully remove the battery by placing the plastic opening tool underneath the indent at the bottom of the battery, and pry it up.
      • There may be adhesive underneath the battery to keep it in place, this may make it a bit difficult to remove the battery.
      Ask FixBot
Adam Mack
299 Reputation
2 Guides authored
USF Tampa, Team 1-2, Sullivan Fall 2016 Member of USF Tampa, Team 1-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G2
3 Members
96 Guides authored
1 Guide Comment
Hi, i’ve bought a battery from amazon to this phone. It has the same specs as the old one, but when i put it to charge (on the phone) it only charges untill half and it stays there. Do i need to buy a different battery or is there a way to fix this?
Eduardo Teixeira - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 29
All Time: 1,852
