Up to 20% off select tools
Nokia Lumia 822 Basic Disassembly
Views: 3.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
99
All Time:
3,203
Comments: 3
3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Please read the entire guide before beginning! Most components in this phone are not user replaceable, as they are soldered directly to the logic board. The few that are replaceable will be removed, or at least pointed out in this guide. I am not responsible for any damage your device may incur.
    1. Nokia Lumia 822 Basic Disassembly, Nokia Lumia 822 Disassembly.: step 1, image 1 of 1
      • Power off the phone.
      Ask FixBot
    2. Nokia Lumia 822 Basic Disassembly: step 2, image 1 of 3 Nokia Lumia 822 Basic Disassembly: step 2, image 2 of 3 Nokia Lumia 822 Basic Disassembly: step 2, image 3 of 3
      • Remove the back cover, the battery, and the sim card with its bracket.
      Ask FixBot
    3. Nokia Lumia 822 Basic Disassembly: step 3, image 1 of 2 Nokia Lumia 822 Basic Disassembly: step 3, image 2 of 2
      • Locate and remove the ten T4 Torx screws around the perimeter of the frame. (indicated by arrows)
      • These screws have threadlocker on them, the amount varies. Occasionally they are so tight that the head twists off. When reassembling, do NOT overtighten them, as this can crack the LCD.
      Ask FixBot
    4. Nokia Lumia 822 Basic Disassembly: step 4, image 1 of 3 Nokia Lumia 822 Basic Disassembly: step 4, image 2 of 3 Nokia Lumia 822 Basic Disassembly: step 4, image 3 of 3
      • Hold the top of the phone's frame between your fingers, and gently apply pressure on the back of the LCD assembly. Do not use too much force. Move your thumbs around to apply pressure at various points.
      • When viewed from the front, the top left corner of the screen will usually be the first to pop loose.
      • Run a plastic opening tool or a thumbnail along the top of the screen to free it from the frame assembly.
      Ask FixBot
    5. Nokia Lumia 822 Basic Disassembly: step 5, image 1 of 3 Nokia Lumia 822 Basic Disassembly: step 5, image 2 of 3 Nokia Lumia 822 Basic Disassembly: step 5, image 3 of 3
      • Once the top of the screen assembly is free, pull it out so it clears the edge of the frame.
      • Pull the screen assembly straight up to free the bottom portion from the frame. The frame can now be set aside, as we will concentrate on the screen/logic board assembly.
      Ask FixBot
    6. Nokia Lumia 822 Basic Disassembly: step 6, image 1 of 2 Nokia Lumia 822 Basic Disassembly: step 6, image 2 of 2
      • Locate the ribbon cable on the back of the logic board and carefully loosen the connector with a plastic opening tool. Be sure you are prying on the cable's connector, and not on the plug on the logic board.
      Ask FixBot
    7. Nokia Lumia 822 Basic Disassembly: step 7, image 1 of 3 Nokia Lumia 822 Basic Disassembly: step 7, image 2 of 3 Nokia Lumia 822 Basic Disassembly: step 7, image 3 of 3
      • There are four small plastic clips that hold the logic board to the screen assembly. Using a small flat screwdriver, carefully pull back clips # 1 and 2, (see photo) and free the logic board on that side.
      • The plastic clips break easily if bent back too far.
      Ask FixBot
    8. Nokia Lumia 822 Basic Disassembly: step 8, image 1 of 3 Nokia Lumia 822 Basic Disassembly: step 8, image 2 of 3 Nokia Lumia 822 Basic Disassembly: step 8, image 3 of 3
      • Raise the logic board by the edge freed in the previous step, and slide it from underneath the remaining clips on the other side.
      • There is a second ribbon cable directly across from the first, on the underside of the logic board, visible in the last two photos.
      • Carefully flip the logic board and set it on the workspace next to the screen assembly. Take care to avoid damaging the ribbon cable.
      Ask FixBot
    9. Nokia Lumia 822 Basic Disassembly: step 9, image 1 of 2 Nokia Lumia 822 Basic Disassembly: step 9, image 2 of 2
      • Use a plastic opening tool to free the ribbon cable connector, again making sure to pry only on the cable's connector.
      • The only replaceable part on the screen assembly is the earpiece speaker, although removing it will ruin the double-sided foam adhesive strip that holds it in place.
      Ask FixBot
    10. Nokia Lumia 822 Basic Disassembly: step 10, image 1 of 1
      • On the logic board, the front facing camera, along with the proximity and light sensors can be removed simply by loosening the connector with a plastic opening tool.
      Ask FixBot
    11. Nokia Lumia 822 Basic Disassembly: step 11, image 1 of 3 Nokia Lumia 822 Basic Disassembly: step 11, image 2 of 3 Nokia Lumia 822 Basic Disassembly: step 11, image 3 of 3
      • To remove the Micro-SD slot, begin by freeing the connector from the logic board using a plastic opening tool.
      • The Micro-SD slot is adhered to the SIM slot using a medium adhesive. Use a hobby knife to free it, carefully sliding it between the two slots.
      • Be sure to move slowly and with as little force as necessary to reduce the chance of injury or damaging a component.
      Ask FixBot
    12. Nokia Lumia 822 Basic Disassembly: step 12, image 1 of 1
      • Basic disassembly is complete.
      • When reassembling, be very careful when connecting ribbon cables. The connectors are delicate. Make sure the connectors are lined up before applying any pressure, and do not use excessive force.
      Ask FixBot
5 other people completed this guide.
Author
with
wingdinger2
315 Reputation
1 Guide authored
3 Guide Comments
Dear,
With many thanks to you. I am interested in connect with you.
Thanks
Sheikh Mizanur Rahman - Reply Share
Your missing prob the thing that breaks most on this phone the usb power supply replacement .
Blue “Blueman” 15 - Reply Share
With respect, you’re missing the point of this guide. It’s basic disassembly. The USB port is soldered to the motherboard and is not replaceable by the average person.
wingdinger2 - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 99
All Time: 3,203
