Nokia Lumia 735 Battery Replacement
    • Turn off the device before starting this process
    Ask FixBot
  1. Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 1): step 2, image 1 of 3 Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 1): step 2, image 2 of 3 Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 1): step 2, image 3 of 3
    • Stick your opening pick between the plastic casing and the screen
    • Move your pick up toward the top corner of the phone
    • Rotate the pick so it is parallel with the back of the phone
    Ask FixBot
  2. Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 2): step 3, image 1 of 3 Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 2): step 3, image 2 of 3 Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 2): step 3, image 3 of 3
    • Move the pick in between the back of the phone and the plastic cover to the top left corner
    • Use the gap made by the pick between the back plastic and the phone to pry apart the two parts
    • The back should now be removed exposing the battery, SIM card, and SD card on the back of the phone
    Ask FixBot
  3. Nokia Lumia 735 Battery Replacement, Remove the Battery: step 4, image 1 of 3 Nokia Lumia 735 Battery Replacement, Remove the Battery: step 4, image 2 of 3 Nokia Lumia 735 Battery Replacement, Remove the Battery: step 4, image 3 of 3
    • Insert the pick into the opening near the top of the battery
    • Use the pick to lift up the battery until you can remove it from its resting place
    • The battery should now be removed from the phone
    Ask FixBot
  4. Nokia Lumia 735 Battery Replacement, Adding the New Battery: step 5, image 1 of 2 Nokia Lumia 735 Battery Replacement, Adding the New Battery: step 5, image 2 of 2
    • Insert the new battery bottom first, lining up the connectors on the battery with the connectors on the phone
    • Slide the battery in and push it down so it stays in its place
    Ask FixBot
  5. Nokia Lumia 735 Battery Replacement, Putting Back on the Back: step 6, image 1 of 2 Nokia Lumia 735 Battery Replacement, Putting Back on the Back: step 6, image 2 of 2
    • Line up the back with the back of the phone
    • Push down on the back until you hear it snap into place
    • Congratulations! You just replaced the battery on your phone, you may turn it back on and begin using it normally.
    Ask FixBot
Daniel Stark
168 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 627
