Nokia Lumia 720 Display Assembly Replacement
Video Overview
    1. Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: step 1, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: step 1, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: step 1, image 3 of 3
      • Remove the SIM card tray and the memory card try.
      • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
      • Use plastic tools and start the separating the back cover from the top side.
      Ask FixBot
    2. Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: step 2, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: step 2, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: step 2, image 3 of 3
      • Be careful with the volume buttons.
      Ask FixBot
    1. Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: step 3, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: step 3, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: step 3, image 3 of 3
      • Remove the 3x Torx T4 screws.
      • Buzzer / Loudspeacker
      Ask FixBot
    1. Nokia Lumia 720 Display Assembly Replacement, BATTERY: step 4, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY: step 4, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY: step 4, image 3 of 3
      • Disconnect the battery flex cable.
      • Unstick the metal foil from the logic board.
      • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
      • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
      Ask FixBot
    1. Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: step 5, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: step 5, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: step 5, image 3 of 3
      • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
      Ask FixBot
    1. Nokia Lumia 720 Display Assembly Replacement, Logic Board: step 6, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Logic Board: step 6, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Logic Board: step 6, image 3 of 3
      • Disconnect the Volume, Power and camera buttons flex cable.
      • Remove the 4x Torx T4 screws.
      • Slightly lift the board
      • Slowly and gently unstuck the light sensor from the middle frame.
      Ask FixBot
    2. Nokia Lumia 720 Display Assembly Replacement: step 7, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement: step 7, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement: step 7, image 3 of 3
      • Disconnect the Display Assembly flex cable.
      • Disconnect the Charging Dock Board flex cable.
      • Remove the Main board.
      Ask FixBot
    1. Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: step 8, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: step 8, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: step 8, image 3 of 3
      • Use a hair dryer and warm the flex cable.
      • Careful unstuck the flex cable from the middle frame.
      • Micro USB connector
      • Microphone
      Ask FixBot
    1. Nokia Lumia 720 Display Assembly Replacement, EARPIECE: step 9, image 1 of 2 Nokia Lumia 720 Display Assembly Replacement, EARPIECE: step 9, image 2 of 2
      • Use a tool with a sharp point and carefully unstuck the earpiece.
      Ask FixBot
    1. Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: step 10, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: step 10, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: step 10, image 3 of 3
      • When you start with the removing the ribbon cable be careful with the buttons and with the small black cups on it.
      • Warm the flex cable and detach it.
      Ask FixBot
    1. Nokia Lumia 720 Display Assembly Replacement, Display Assembly: step 11, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Display Assembly: step 11, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Display Assembly: step 11, image 3 of 3
      • Now you can start with the reassembling, but before you place the back cover, test the new display assembly.
      • When you put the lid be careful with the volume buttons.
      Ask FixBot
    2. Nokia Lumia 720 Display Assembly Replacement: step 12, image 1 of 1
      • That's all.
      • Did you do it successfully?
      Ask FixBot
5 other people completed this guide.
ZFix
197,612 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
334 Members
8,251 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 42
All Time: 6,350
