Nokia Lumia 635 Display Assembly Replacement
Video Overview
    1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: step 1, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: step 1, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: step 1, image 3 of 3
      • Switch off the phone.
      • Remove the battery and any installed SIM and memory cards.
      • Remove the black tape near to the loudspeaker.
      Ask FixBot
    2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: step 2, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: step 2, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: step 2, image 3 of 3
      • Remove the 9x Torx T4 screws.
      • Two of them are with the same head size but with a different length.
      Ask FixBot
    3. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: step 3, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: step 3, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: step 3, image 3 of 3
      • Use a plastic opening tool to remove the back cover.
      • Careful unhook the display assembly flex cable.
      Ask FixBot
    4. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: step 4, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: step 4, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: step 4, image 3 of 3
      • Insert wisdom here.
      Ask FixBot
    5. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: step 5, image 1 of 2 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: step 5, image 2 of 2
      • Put some scotch tape to prevent the glass from scattering.
      • Use a hot gun or hair dryer and warm the glass to soften the adhesive.
      Ask FixBot
    6. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: step 6, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: step 6, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: step 6, image 3 of 3
      • Start the separating from the upper right corner, where you have an hole in the middle frame.
      • Use plastic tool to prevent the middle frame from scratches.
      • Work slowly, you can cut your fingers.
      Ask FixBot
    7. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: step 7, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: step 7, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: step 7, image 3 of 3
      • Clean the middle farme.
      • Put adhesive tape 3MM.
      • Be careful, don't cover the technological openings on the middle frame (for the light sensor, earpiece, etc.).
      • It's easier if you order the spare part together with an adhesive tape.
      • Install the display assembly.
      Ask FixBot
    8. Nokia Lumia 635 Display Assembly Replacement: step 8, image 1 of 2 Nokia Lumia 635 Display Assembly Replacement: step 8, image 2 of 2
      • That's all.
      • Did you do it successfully?
      Ask FixBot
5 other people completed this guide.
ZFix
197,675 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
335 Members
8,260 Guides authored
2 Guide Comments
Exactly what I needed! Step by step detailed instructions along with what tools I would need. Heating it up took longer than expected & it took me longer than 30 min, but I actually set aside 2 hours to replace my screen. Woohoo I finally I have a new screen & I did it all on my own...well with the amazing help from ZFix ;D
beatriz_ibre - Reply Share
how to fix the display
Roneil Mcintosh - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 111
All Time: 10,730
