Nokia Lumia 620 Volume and Power Button Replacement
    1. Nokia Lumia 620 Volume and Power Button Replacement, Volume and Power Button: step 1, image 1 of 1
      • Check condition of switches on logicboard
      • Rule out failure of cover
      Ask FixBot
    2. Nokia Lumia 620 Volume and Power Button Replacement: step 2, image 1 of 1
      • Torx 6 screwdriver
      • Soldering iron (thin tip)
      • Decent quality solder (thin wire)
      Ask FixBot
    3. Nokia Lumia 620 Volume and Power Button Replacement: step 3, image 1 of 1
      • Remove cover, battery and SIM
      • Remove 6 torx screws
      • Note: Green is fine thread
      • Note: Red is coarse thread
      Ask FixBot
    4. Nokia Lumia 620 Volume and Power Button Replacement: step 4, image 1 of 2 Nokia Lumia 620 Volume and Power Button Replacement: step 4, image 2 of 2
      • Remove plastic clover near battery
      • Keep track of all parts
      Ask FixBot
    5. Nokia Lumia 620 Volume and Power Button Replacement: step 5, image 1 of 1
      • Gently release logicboard connectors
      Ask FixBot
    6. Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: step 6, image 1 of 2 Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: step 6, image 2 of 2
      • There is a clip that needs to be moved out of the way before the board will move.
      • Start by lifting long side of logicboard
      • Gently wiggle and lift
      • Undo plastic clips near battery with force
      Ask FixBot
    7. Nokia Lumia 620 Volume and Power Button Replacement: step 7, image 1 of 1
      • Check connections of failed buttons
      Ask FixBot
    8. Nokia Lumia 620 Volume and Power Button Replacement: step 8, image 1 of 1
      • Resolder broken connections
      • Make sure the pads do not short
      Ask FixBot
    9. Nokia Lumia 620 Volume and Power Button Replacement: step 9, image 1 of 1
      • Put back logicboard
      • Make sure pins near camera line-up
      • Note: Plastic clips need quite some force
      Ask FixBot
    10. Nokia Lumia 620 Volume and Power Button Replacement: step 10, image 1 of 1
      • Reconnect logicboard connectors
      Ask FixBot
    11. Nokia Lumia 620 Volume and Power Button Replacement: step 11, image 1 of 1
      • Put back plastic cover
      Ask FixBot
    12. Nokia Lumia 620 Volume and Power Button Replacement: step 12, image 1 of 1
      • Gently tighten screws
      • Put back SIM card and battery
      • Close cover
      • Enjoy the result ;)
      Ask FixBot
Finish Line
11 other people completed this guide.
Anne
456 Reputation
1 Guide authored
4 Guide Comments
Realmente funcionó el tutorial, sirven de nuevo los dos botones que fallaban.
Gaia501 - Reply Share
Only the 2 middle screws are fine threaded. And you can see in the pictures here, that there are 4 coarse threaded ones and 2 fine threaded ones. The green one in the corner should be red
shadow118 - Reply Share
hafıza kart okuyucu çalışmıyor ne yapmam lazım
davutcigir - Reply Share
Omg it looks complicated
Maz Hanvey - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 145
All Time: 10,876
