Nokia Lumia 521 SIM Card Replacement
    1. Nokia Lumia 521 SIM Card Replacement, Battery: step 1, image 1 of 2 Nokia Lumia 521 SIM Card Replacement, Battery: step 1, image 2 of 2
      • Push the plastic opening tool in between the screen and the back case of the phone.
      • Pry the top of the phone between the case and screen until they are separated.
      Ask FixBot
    2. Nokia Lumia 521 SIM Card Replacement: step 2, image 1 of 1
      • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
      Ask FixBot
    1. Nokia Lumia 521 SIM Card Replacement, SIM Card: step 3, image 1 of 1
      • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
      Ask FixBot
Marko Stanisic
322 Reputation
2 Guides authored
USF Tampa, Team 2-4, Sullivan Spring 2016 Member of USF Tampa, Team 2-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 62
All Time: 2,093
