Nokia Lumia 521 Battery Replacement
  1. Nokia Lumia 521 Battery Replacement, Battery: step 1, image 1 of 2 Nokia Lumia 521 Battery Replacement, Battery: step 1, image 2 of 2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 Battery Replacement: step 2, image 1 of 1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
Selamawi Ambaye
261 Reputation
2 Guides authored
USF Tampa, Team 2-4, Sullivan Spring 2016 Member of USF Tampa, Team 2-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 53
All Time: 971
