Up to 20% off select tools
Nokia Lumia 520 Touchscreen Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
27
Past 30 Days:
121
All Time:
2,532
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Follow this guide to repair the glass and frame.
    1. Nokia Lumia 520 Touchscreen  Replacement, Touchscreen and LCD: step 1, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    2. Nokia Lumia 520 Touchscreen  Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    3. Nokia Lumia 520 Touchscreen  Replacement: step 3, image 1 of 1
      • Remove 5 long screws, pink arrow
      • Remove 3 short screws, blue arrow
      Ask FixBot
    4. Nokia Lumia 520 Touchscreen  Replacement: step 4, image 1 of 2 Nokia Lumia 520 Touchscreen  Replacement: step 4, image 2 of 2
      • With a thin tool, unhook the central body from the back cover, along the entire profile of the phone
      Ask FixBot
    5. Nokia Lumia 520 Touchscreen  Replacement: step 5, image 1 of 3 Nokia Lumia 520 Touchscreen  Replacement: step 5, image 2 of 3 Nokia Lumia 520 Touchscreen  Replacement: step 5, image 3 of 3
      • Unclip the touchscreen connector
      • Unhook the display connector
      • Unhook the motherboard from the central phone body
      Ask FixBot
    6. Nokia Lumia 520 Touchscreen  Replacement: step 6, image 1 of 2 Nokia Lumia 520 Touchscreen  Replacement: step 6, image 2 of 2
      • Pull up the central frame from the touchscreen assembly by lifting the clips on the perimeter with a thin tool.
      Ask FixBot
    7. Nokia Lumia 520 Touchscreen  Replacement: step 7, image 1 of 1
      • Remove the light sensor from the old frame with the help of a heat source.
      • Insert the sensor in the new frame.
      Ask FixBot
    8. Nokia Lumia 520 Touchscreen  Replacement: step 8, image 1 of 3 Nokia Lumia 520 Touchscreen  Replacement: step 8, image 2 of 3 Nokia Lumia 520 Touchscreen  Replacement: step 8, image 3 of 3
      • Remove film that protects double-sided adhesive from the new touchscreen glass
      • Insert flat touchscreen into the frame slot and adhere the double sided adhesive to the frame by placing it in the correct position
      Ask FixBot
To reassemble the device, follow these instructions in reverse order.
5 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Smilzo
12,407 Reputation
39 Guides authored
1 Guide Comment
Can the phone reboot with a gone touch screen?
amar harihar - Reply Share
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 121
All Time: 2,532
