Nokia Lumia 520 Power/Volume Switch Replacement
    1. Nokia Lumia 520 Power/Volume Switch Replacement, Battery: step 1, image 1 of 2 Nokia Lumia 520 Power/Volume Switch Replacement, Battery: step 1, image 2 of 2
      • Insert the spudger (non damaging nylon stick tool) into the crevice located between the back cover of the phone and the body of the phone.
      Ask FixBot
    2. Nokia Lumia 520 Power/Volume Switch Replacement: step 2, image 1 of 2 Nokia Lumia 520 Power/Volume Switch Replacement: step 2, image 2 of 2
      • Lift the spudger gently to separate the back cover of the phone and the body of the phone.
      Ask FixBot
    3. Nokia Lumia 520 Power/Volume Switch Replacement: step 3, image 1 of 2 Nokia Lumia 520 Power/Volume Switch Replacement: step 3, image 2 of 2
      • Insert the spudger into the space between the battery and the battery holder, then lift gently to remove the battery.
      Ask FixBot
    1. Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: step 4, image 1 of 3 Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: step 4, image 2 of 3 Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: step 4, image 3 of 3
      • Remove the eight screws in the body of the phone using the T4 Torx screwdriver.
      Ask FixBot
    2. Nokia Lumia 520 Power/Volume Switch Replacement: step 5, image 1 of 2 Nokia Lumia 520 Power/Volume Switch Replacement: step 5, image 2 of 2
      • Slowly and carefully use your spudger to remove the plastic casing over the motherboard.
      Ask FixBot
    3. Nokia Lumia 520 Power/Volume Switch Replacement: step 6, image 1 of 2 Nokia Lumia 520 Power/Volume Switch Replacement: step 6, image 2 of 2
      • Using your spudger, carefully unclip the digitizer touch screen cable. Next unclip the display screen cable.
      Ask FixBot
    4. Nokia Lumia 520 Power/Volume Switch Replacement: step 7, image 1 of 2 Nokia Lumia 520 Power/Volume Switch Replacement: step 7, image 2 of 2
      • Gently remove the motherboard with your hands.
      • Flip it over. Then turn it 90 degrees counterclockwise. Ensure the switches (pictured) are facing you.
      • You will see four small switches close to the side of the circuit board.
      Ask FixBot
    5. Nokia Lumia 520 Power/Volume Switch Replacement: step 8, image 1 of 1
      • Gently take the power/volume switches off using a pair of needle nose pliers. Once removed, gently clean the solder that was there. Replace the solder with a new coat of solder.
      • Check out iFixit's soldering guides, here.
      Ask FixBot
4 other people completed this guide.
Eduardo Perez
189 Reputation
1 Guide authored
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 39
All Time: 6,255
