Nokia G42 5G Charging Port Assembly Replacement
  1. Nokia G42 5G Charging Port Assembly Replacement, Eject the SIM card tray: step 1, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Eject the SIM card tray: step 1, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Eject the SIM card tray: step 1, image 3 of 3
    • Power down your phone and unplug any cables.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
    • Press firmly to eject the tray.
  2. Nokia G42 5G Charging Port Assembly Replacement, Remove the SIM card tray: step 2, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Remove the SIM card tray: step 2, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Remove the SIM card tray: step 2, image 3 of 3
    • Remove the SIM card tray.
    • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
  3. Nokia G42 5G Charging Port Assembly Replacement, Insert an opening pick: step 3, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Insert an opening pick: step 3, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Insert an opening pick: step 3, image 3 of 3
    • The back cover is held in place by plastic clips.
    • Insert an opening pick under the small notch in the SIM card tray slot.
  4. Nokia G42 5G Charging Port Assembly Replacement, Release the plastic clips: step 4, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Release the plastic clips: step 4, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Release the plastic clips: step 4, image 3 of 3
    • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
    • Slide the opening pick down the left edge of the phone to release the plastic clips.
  5. Nokia G42 5G Charging Port Assembly Replacement: step 5, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement: step 5, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement: step 5, image 3 of 3
    • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
  6. Nokia G42 5G Charging Port Assembly Replacement: step 6, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement: step 6, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement: step 6, image 3 of 3
    • Slide the opening pick up the right edge to continue releasing the plastic clips.
  7. Nokia G42 5G Charging Port Assembly Replacement: step 7, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement: step 7, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement: step 7, image 3 of 3
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to fully remove the back cover just yet, as it's still connected with a cable.
  8. Nokia G42 5G Charging Port Assembly Replacement, Flip open the back cover: step 8, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Flip open the back cover: step 8, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Flip open the back cover: step 8, image 3 of 3
    • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
    • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
    • Lay the back cover next to the phone.
  9. Nokia G42 5G Charging Port Assembly Replacement, Unfasten the fingerprint reader bracket: step 9, image 1 of 1
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
  10. Nokia G42 5G Charging Port Assembly Replacement, Remove the fingerprint reader bracket: step 10, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Remove the fingerprint reader bracket: step 10, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Remove the fingerprint reader bracket: step 10, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
    • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
    • During reassembly, make sure to slide the bracket's edge back into its slot under the motherboard cover.
  11. Nokia G42 5G Charging Port Assembly Replacement, Disconnect the fingerprint reader: step 11, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Disconnect the fingerprint reader: step 11, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Disconnect the fingerprint reader: step 11, image 3 of 3
    • Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Remove the back cover.
  12. Nokia G42 5G Charging Port Assembly Replacement, Unfasten the motherboard cover: step 12, image 1 of 1
    • A white sticker might cover one of the top screws. Pierce through it with the tip of your screwdriver or use a pair of tweezers to remove it.
    • Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
  13. Nokia G42 5G Charging Port Assembly Replacement, Pry up the motherboard cover: step 13, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Pry up the motherboard cover: step 13, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Pry up the motherboard cover: step 13, image 3 of 3
    • The motherboard cover is further held in place by plastic clips.
    • Insert an opening pick under the right edge of the motherboard cover.
    • Twist the opening pick to release the plastic clips.
    • During reassembly, clip in the motherboard cover on the top left first.
  14. Nokia G42 5G Charging Port Assembly Replacement, Remove the motherboard cover: step 14, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Remove the motherboard cover: step 14, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Remove the motherboard cover: step 14, image 3 of 3
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
  15. Nokia G42 5G Charging Port Assembly Replacement, Disconnect the battery cable: step 15, image 1 of 2 Nokia G42 5G Charging Port Assembly Replacement, Disconnect the battery cable: step 15, image 2 of 2
    • Use the flat end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  16. Nokia G42 5G Charging Port Assembly Replacement, Unfasten the loudspeaker: step 16, image 1 of 1
  17. Nokia G42 5G Charging Port Assembly Replacement, Pry up the loudspeaker: step 17, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Pry up the loudspeaker: step 17, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Pry up the loudspeaker: step 17, image 3 of 3
    • Insert an opening pick underneath the top right edge of the loudspeaker.
    • Avoid pushing down at a sharp angle, or you risk damaging the interconnect ribbon cable underneath.
    • Twist the opening pick to release loudspeaker from the plastic clips holding it in place.
  18. Nokia G42 5G Charging Port Assembly Replacement, Remove the loudspeaker: step 18, image 1 of 2 Nokia G42 5G Charging Port Assembly Replacement, Remove the loudspeaker: step 18, image 2 of 2
    • Use a pair of tweezers or your fingers to remove the loudspeaker.
  19. Nokia G42 5G Charging Port Assembly Replacement, Disconnect the interconnect cable: step 19, image 1 of 2 Nokia G42 5G Charging Port Assembly Replacement, Disconnect the interconnect cable: step 19, image 2 of 2
    • Use the flat end of a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  20. Nokia G42 5G Charging Port Assembly Replacement, Disconnect the antenna cables: step 20, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Disconnect the antenna cables: step 20, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Disconnect the antenna cables: step 20, image 3 of 3
    • Use a spudger to disconnect the antenna cables by prying their coaxial connectors straight up from the sockets on the board.
  21. Nokia G42 5G Charging Port Assembly Replacement, Reposition the antenna cables: step 21, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Reposition the antenna cables: step 21, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Reposition the antenna cables: step 21, image 3 of 3
    Buy
    • Use a pair of tweezers or your fingers to grip the antenna cables near the connectors.
    • Reposition the antenna cables out of the way of the charging port assembly.
  22. Nokia G42 5G Charging Port Assembly Replacement, Pry up the charging port assembly: step 22, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Pry up the charging port assembly: step 22, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Pry up the charging port assembly: step 22, image 3 of 3
    • The top edge of the charging port assembly is held in place with adhesive.
    • Insert the flat end of a spudger underneath the top right edge of the charging port assembly.
    • Pivot the charging port assembly up until you can grip it with your fingers.
  23. Nokia G42 5G Charging Port Assembly Replacement, Remove the charging port assembly: step 23, image 1 of 2 Nokia G42 5G Charging Port Assembly Replacement, Remove the charging port assembly: step 23, image 2 of 2
    • Use your fingers or a pair of tweezers to remove the charging port assembly.
  24. Nokia G42 5G Charging Port Assembly Replacement, Remove the rubber gaskets: step 24, image 1 of 3 Nokia G42 5G Charging Port Assembly Replacement, Remove the rubber gaskets: step 24, image 2 of 3 Nokia G42 5G Charging Port Assembly Replacement, Remove the rubber gaskets: step 24, image 3 of 3
    • Use a pair of tweezers to remove the two black U-shaped rubber gaskets from the charging port and the headphone jack.
    • Only the charging port assembly remains.
    • During reassembly, transfer the rubber gaskets to the replacement board before securing it back into the frame.
3 other people completed this guide.
Manuel Haeussermann
25,295 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
123 Members
25,686 Guides authored
3 Guide Comments
Success!If I can do it anyone can. How ever if I never have to reconnect antennae cables and finger print readers again it will be too soon.
Badger - Reply Share
Great! Took me a bit longer than expected (1h30) but I was delivered with sausages for fingers.
Corentin Benoit - Reply Share
Excellent guide; successfully followed; thank you bundles!
Daniel Klein - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 122
All Time: 3,875
