Nokia G42 5G Back Cover Replacement
    1. Nokia G42 5G Back Cover Replacement, Eject the SIM card tray: step 1, image 1 of 3 Nokia G42 5G Back Cover Replacement, Eject the SIM card tray: step 1, image 2 of 3 Nokia G42 5G Back Cover Replacement, Eject the SIM card tray: step 1, image 3 of 3
      • Power down your phone and unplug any cables.
      • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
      • Press firmly to eject the tray.
      Ask FixBot
    2. Nokia G42 5G Back Cover Replacement, Remove the SIM card tray: step 2, image 1 of 3 Nokia G42 5G Back Cover Replacement, Remove the SIM card tray: step 2, image 2 of 3 Nokia G42 5G Back Cover Replacement, Remove the SIM card tray: step 2, image 3 of 3
      • Remove the SIM card tray.
      • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
      Ask FixBot
    1. Nokia G42 5G Back Cover Replacement, Insert an opening pick: step 3, image 1 of 3 Nokia G42 5G Back Cover Replacement, Insert an opening pick: step 3, image 2 of 3 Nokia G42 5G Back Cover Replacement, Insert an opening pick: step 3, image 3 of 3
      • The back cover is held in place by plastic clips.
      • Insert an opening pick under the small notch in the SIM card tray slot.
      Ask FixBot
    2. Nokia G42 5G Back Cover Replacement, Release the plastic clips: step 4, image 1 of 3 Nokia G42 5G Back Cover Replacement, Release the plastic clips: step 4, image 2 of 3 Nokia G42 5G Back Cover Replacement, Release the plastic clips: step 4, image 3 of 3
      • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
      • Slide the opening pick down the left edge of the phone to release the plastic clips.
      Ask FixBot
    3. Nokia G42 5G Back Cover Replacement: step 5, image 1 of 3 Nokia G42 5G Back Cover Replacement: step 5, image 2 of 3 Nokia G42 5G Back Cover Replacement: step 5, image 3 of 3
      • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
      Ask FixBot
    4. Nokia G42 5G Back Cover Replacement: step 6, image 1 of 3 Nokia G42 5G Back Cover Replacement: step 6, image 2 of 3 Nokia G42 5G Back Cover Replacement: step 6, image 3 of 3
      • Slide the opening pick up the right edge to continue releasing the plastic clips.
      Ask FixBot
    5. Nokia G42 5G Back Cover Replacement: step 7, image 1 of 3 Nokia G42 5G Back Cover Replacement: step 7, image 2 of 3 Nokia G42 5G Back Cover Replacement: step 7, image 3 of 3
      • Slide the opening pick along the top edge to release the remaining plastic clips.
      • Don't try to fully remove the back cover just yet, as it's still connected with a cable.
      Ask FixBot
    6. Nokia G42 5G Back Cover Replacement, Flip open the back cover: step 8, image 1 of 3 Nokia G42 5G Back Cover Replacement, Flip open the back cover: step 8, image 2 of 3 Nokia G42 5G Back Cover Replacement, Flip open the back cover: step 8, image 3 of 3
      • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
      • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
      • Lay the back cover next to the phone.
      Ask FixBot
    7. Nokia G42 5G Back Cover Replacement, Unfasten the fingerprint reader bracket: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
      Ask FixBot
    8. Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader bracket: step 10, image 1 of 3 Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader bracket: step 10, image 2 of 3 Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader bracket: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
      • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
      • During reassembly, make sure to slide the bracket's edge back into its slot under the motherboard cover.
      Ask FixBot
    9. Nokia G42 5G Back Cover Replacement, Disconnect the fingerprint reader: step 11, image 1 of 3 Nokia G42 5G Back Cover Replacement, Disconnect the fingerprint reader: step 11, image 2 of 3 Nokia G42 5G Back Cover Replacement, Disconnect the fingerprint reader: step 11, image 3 of 3
      • Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      • Remove the back cover.
      Ask FixBot
    1. Nokia G42 5G Back Cover Replacement, Release the fingerprint reader: step 12, image 1 of 3 Nokia G42 5G Back Cover Replacement, Release the fingerprint reader: step 12, image 2 of 3 Nokia G42 5G Back Cover Replacement, Release the fingerprint reader: step 12, image 3 of 3
      • Using a pair of tweezers, grip the top of the fingerprint reader and lift it out and around the top plastic tab, separating it from the back cover.
      Ask FixBot
    2. Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader: step 13, image 1 of 3 Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader: step 13, image 2 of 3 Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader: step 13, image 3 of 3
      • Use a pair of tweezers to lift the fingerprint reader out of its bottom plastic tab.
      • Remove the fingerprint reader.
      • During reassembly, you'll need to transfer the fingerprint reader to the new back cover.
      Ask FixBot
    1. Nokia G42 5G Back Cover Replacement, Only the back cover remains: step 14, image 1 of 1
      • Only the back cover remains.
      Ask FixBot
3 other people completed this guide.
Manuel Haeussermann
27,023 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
3 Guide Comments
Very simple and to the point! Worked like a charm. The only qualm I have is that the replacement did not have camera lens covers. They had little blue plastic circles over them but once you bring those up, there’s nothing underneath.
I ordered this to replace the back on my G310 5G and it does fit!
Jacqueline Taylor - Reply Share
Comment on démonte les lentilles ?
hawai_ Léo - Reply Share
Hey, how do I transfer lens cover???
Marko Shapochka - Reply Share
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 148
All Time: 5,573
