Nokia E90 QWERTY Keyboard Replacement
    1. Nokia E90 QWERTY Keyboard Replacement, Battery Cover and Battery: step 1, image 1 of 1
      • In order to remove the back cover, you must press the indicated button.
      Ask FixBot
    2. Nokia E90 QWERTY Keyboard Replacement: step 2, image 1 of 2 Nokia E90 QWERTY Keyboard Replacement: step 2, image 2 of 2
      • With the button pressed, apply light pressure and slide the back cover off.
      • This will allow you to access the battery
      Ask FixBot
    3. Nokia E90 QWERTY Keyboard Replacement: step 3, image 1 of 1
      • In order to remove the battery, pull it out from the same side that the rubber button is on.
      Ask FixBot
    1. Nokia E90 QWERTY Keyboard Replacement, Back Cover: step 4, image 1 of 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: step 4, image 2 of 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: step 4, image 3 of 3
      • Using a plastic opening tool, separate the back cover from the phone.
      Ask FixBot
    2. Nokia E90 QWERTY Keyboard Replacement: step 5, image 1 of 2 Nokia E90 QWERTY Keyboard Replacement: step 5, image 2 of 2
      • Continue along the edge with the plastic opening tool.
      Ask FixBot
    3. Nokia E90 QWERTY Keyboard Replacement: step 6, image 1 of 3 Nokia E90 QWERTY Keyboard Replacement: step 6, image 2 of 3 Nokia E90 QWERTY Keyboard Replacement: step 6, image 3 of 3
      • Gently, remove the back cover.
      Ask FixBot
    1. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: step 7, image 1 of 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: step 7, image 2 of 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: step 7, image 3 of 3
      • Unscrew the indicated screws using the T5 screwdriver.
      Ask FixBot
    2. Nokia E90 QWERTY Keyboard Replacement: step 8, image 1 of 2 Nokia E90 QWERTY Keyboard Replacement: step 8, image 2 of 2
      • Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
      • Be careful not to break the plastic during this step; do your best not to force anything.
      Ask FixBot
    3. Nokia E90 QWERTY Keyboard Replacement: step 9, image 1 of 2 Nokia E90 QWERTY Keyboard Replacement: step 9, image 2 of 2
      • The button board will be loose once the cover is removed.
      • Lift it up to reveal the sensor board.
      Ask FixBot
    4. Nokia E90 QWERTY Keyboard Replacement: step 10, image 1 of 2 Nokia E90 QWERTY Keyboard Replacement: step 10, image 2 of 2
      • With the T5 Screwdriver, remove the marked screws.
      Ask FixBot
    5. Nokia E90 QWERTY Keyboard Replacement: step 11, image 1 of 2 Nokia E90 QWERTY Keyboard Replacement: step 11, image 2 of 2
      • With the screws removed, the sensor board should be free to flip up.
      Ask FixBot
    6. Nokia E90 QWERTY Keyboard Replacement: step 12, image 1 of 2 Nokia E90 QWERTY Keyboard Replacement: step 12, image 2 of 2
      • Disconnect the wire with the plastic opening tool.
      Ask FixBot
    7. Nokia E90 QWERTY Keyboard Replacement: step 13, image 1 of 3 Nokia E90 QWERTY Keyboard Replacement: step 13, image 2 of 3 Nokia E90 QWERTY Keyboard Replacement: step 13, image 3 of 3
      • Remove the screws marked.
      • The Screw on the left is located underneath the cable.
      • With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
      Ask FixBot
4 other people completed this guide.
Cameron Weinberg
591 Reputation
6 Guides authored
Cal Poly, Team 18-21, Garner Spring 2011 Member of Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 42
All Time: 6,996
