Up to 20% off select tools
Nokia E90 Front Cover Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
96
All Time:
5,883
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This guide requires a T5 screwdriver for the screws.
    1. Nokia E90 Front Cover Replacement, Front Cover: step 1, image 1 of 1
      • Start with the phone in the flipped open position.
      • You must remove the sticker in the center, below the screen to reveal the center screw.
      • Use a T5 screwdriver to remove all three screws, loosening the front screen.
      Ask FixBot
    2. Nokia E90 Front Cover Replacement: step 2, image 1 of 2 Nokia E90 Front Cover Replacement: step 2, image 2 of 2
      • Flip the phone to the closed position and turn to the front screen.
      • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
      Ask FixBot
Author
with
Cameron Weinberg
591 Reputation
6 Guides authored
Cal Poly, Team 18-21, Garner Spring 2011 Member of Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Members
84 Guides authored
2 Guide Comments
I have a n90 done which will not switch on. I have changed the battery and still nothing.pressing the top power button but nothing.trying to get old pics off the phone any help?
Smith - Reply Share
Hello Mr Smith. Have you tried to recharge the battery as it is in the phone in question? Recharge the battery while it is in the phone first, IF the phone in question still does not boot up then get another battery from ebay. I have a similar E90 as yours and the battery did go flat in the end, like all batteries, I just got a new battery and then recharged the battery while it is in the phone. Good luck.
Keith N Searle - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 96
All Time: 5,883
