Up to 20% off select tools
Nokia E71x Camera Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
23
Past 30 Days:
111
All Time:
2,223
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
To complete this repair you will need a Torx number 4
    1. Nokia E71x Camera Replacement, Motherboard: step 1, image 1 of 2 Nokia E71x Camera Replacement, Motherboard: step 1, image 2 of 2
      • Remove battery
      Ask FixBot
    2. Nokia E71x Camera Replacement: step 2, image 1 of 1
      • Using Torx number 4 unscrew the four 0.5mm screws.
      Ask FixBot
    3. Nokia E71x Camera Replacement: step 3, image 1 of 1
      • Push in four clips to detach the body.
      Ask FixBot
    4. Nokia E71x Camera Replacement: step 4, image 1 of 3 Nokia E71x Camera Replacement: step 4, image 2 of 3 Nokia E71x Camera Replacement: step 4, image 3 of 3
      • Separate the body into two pieces.
      • Be careful not to damage the screen or body. Some force will be needed to separate the body.
      Ask FixBot
    5. Nokia E71x Camera Replacement: step 5, image 1 of 3 Nokia E71x Camera Replacement: step 5, image 2 of 3 Nokia E71x Camera Replacement: step 5, image 3 of 3
      • Remove the bottom piece that is clipped on.
      • Some force will need to be exerted to remove the clip.
      Ask FixBot
    6. Nokia E71x Camera Replacement: step 6, image 1 of 1
      • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
      Ask FixBot
    7. Nokia E71x Camera Replacement: step 7, image 1 of 2 Nokia E71x Camera Replacement: step 7, image 2 of 2
      • Once screws are removed detach back of phone from the motherboard.
      • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
      Ask FixBot
    8. Nokia E71x Camera Replacement: step 8, image 1 of 1
      • Replace motherboard, ensure that replacement has the same serial number.
      Ask FixBot
    1. Nokia E71x Camera Replacement, Camera: step 9, image 1 of 2 Nokia E71x Camera Replacement, Camera: step 9, image 2 of 2
      • Carefully un-clip camera ribbon. Install new camera.
      Ask FixBot
3 other people completed this guide.
Author
with
Will Goldby
187 Reputation
4 Guides authored
Cuesta, Team 1-1, Zipperian Fall 2011 Member of Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Members
48 Guides authored
1 Guide Comment
Will a Nokia E72 replacement camera part work in the Nokia E71 motherboard? In other words, can one upgrade the Nokia E71’s 3.2 MP camera to 5.0 MP using a spare part made for an E72?
Gam - Reply Share
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 111
All Time: 2,223
