Up to 20% off select tools
Nokia E71x Battery Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
91
All Time:
1,865
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Moderate
Introduction
Go to step 1 ↓
Experiencing power issues with your Nokia E71x? A failing battery could be the culprit. This guide is designed to walk you through the process of easily replacing the battery in your Nokia E71x. No special tools are needed, making this a perfect task for DIY enthusiasts and first-time fixers alike. Follow these simple steps to breathe new life into your phone.
Before You Start: Quick Preparation Guide
  1. Turn Off Your Phone: Make sure your Nokia E71x is completely powered off to avoid any electrical issues.
  2. Set Up Your Space: Find a clean and stable surface to work on. Use a soft cloth to protect your phone from scratches.
  3. Have Your New Battery Ready: Ensure you have the correct replacement battery for the Nokia E71x at hand.
  4. Backup Your Data: It's a good idea to back up your important files just in case, to another device or cloud storage.
    1. Nokia E71x Battery Replacement, Battery: step 1, image 1 of 2 Nokia E71x Battery Replacement, Battery: step 1, image 2 of 2
      • Use your fingers to lift the battery out of the phone.
      Ask FixBot
Once the new battery is securely installed, you are ready to put your phone back together. Simply reverse the steps you followed to disassemble your Nokia E71x. Make sure all components fit snugly back into their places. Power on your device to ensure everything is working correctly. Congratulations on successfully replacing your battery! Your Nokia E71x should now be ready.
Author
with
Will Goldby
187 Reputation
4 Guides authored
Cuesta, Team 1-1, Zipperian Fall 2011 Member of Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 91
All Time: 1,865
