Up to 20% off select tools
Nokia E62 Complete Disassembly
Views: 7.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
99
All Time:
7,757
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Nokia E62 Complete Disassembly, Nokia E62 Complete Disassembly: step 1, image 1 of 1
      • To start, press one of the latches at the top of the phone to open the rear cover.
      Ask FixBot
    2. Nokia E62 Complete Disassembly: step 2, image 1 of 1
      • Carefully press the other latch.
      Ask FixBot
    3. Nokia E62 Complete Disassembly: step 3, image 1 of 1
      • Open rear cover by this side.
      Ask FixBot
    4. Nokia E62 Complete Disassembly: step 4, image 1 of 1
      • Press the three latches to open this side of the cover.
      Ask FixBot
    5. Nokia E62 Complete Disassembly: step 5, image 1 of 1
      • Remove the rear cover.
      Ask FixBot
    6. Nokia E62 Complete Disassembly: step 6, image 1 of 1
      • Removed rear cover. See the latches .
      Ask FixBot
    7. Nokia E62 Complete Disassembly: step 7, image 1 of 1
      • Remove the screws using Torx T6 screw driver.
      Ask FixBot
    8. Nokia E62 Complete Disassembly: step 8, image 1 of 1
      • Remove six T6 screws.
      Ask FixBot
    9. Nokia E62 Complete Disassembly: step 9, image 1 of 1
      • Remove the assembly. The front cover will be released.
      Ask FixBot
    10. Nokia E62 Complete Disassembly: step 10, image 1 of 1
      • The front cover released.
      Ask FixBot
    11. Nokia E62 Complete Disassembly: step 11, image 1 of 1
      • To remove the display , unscrew the T6 Torx at top.
      Ask FixBot
    12. Nokia E62 Complete Disassembly: step 12, image 1 of 1
      • CAUTION! Remove the bottom screw with T5 Torx screw driver, not T6 !
      Ask FixBot
    13. Nokia E62 Complete Disassembly: step 13, image 1 of 1
      • Carefully disconnect the Flex cable connector. Then remove the display.
      Ask FixBot
    14. Nokia E62 Complete Disassembly: step 14, image 1 of 1
      • Carefully remove the adhesive keyboard membrane.
      • You can replace it at this step if you need to.
      Ask FixBot
    15. Nokia E62 Complete Disassembly: step 15, image 1 of 1
      • You can clean the keyboard surface with alcohol, if you dropped a drink here.
      Ask FixBot
    16. Nokia E62 Complete Disassembly: step 16, image 1 of 1
      • When you replace the keyboard membrane, align the two contacts at bottom.
      Ask FixBot
    17. Nokia E62 Complete Disassembly: step 17, image 1 of 1
      • You can wash the front cover and keyboard if they are dirty.
      Ask FixBot
    18. Nokia E62 Complete Disassembly: step 18, image 1 of 1
      • Keyboard - clean it if necessary.
      Ask FixBot
    19. Nokia E62 Complete Disassembly: step 19, image 1 of 1
      • Rear side of the circuit board.
      Ask FixBot
    20. Nokia E62 Complete Disassembly: step 20, image 1 of 1
      • Speaker and antenna contacts.
      Ask FixBot
    21. Nokia E62 Complete Disassembly: step 21, image 1 of 1
      • If necessary, you can replace the joystick, the button module or the connector housing.
      Ask FixBot
3 other people completed this guide.
Author
with
Jose Gustavo Abreu Murta
5,212 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 99
All Time: 7,757
