Nokia E61i Headset Jack Replacement
  1. Nokia E61i Headset Jack Replacement, Battery: step 1, image 1 of 2 Nokia E61i Headset Jack Replacement, Battery: step 1, image 2 of 2
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
    Ask FixBot
  2. Nokia E61i Headset Jack Replacement: step 2, image 1 of 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
    Ask FixBot
  3. Nokia E61i Headset Jack Replacement: step 3, image 1 of 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
    Ask FixBot
  4. Nokia E61i Headset Jack Replacement, Front Cover: step 4, image 1 of 2 Nokia E61i Headset Jack Replacement, Front Cover: step 4, image 2 of 2
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
    Ask FixBot
  5. Nokia E61i Headset Jack Replacement: step 5, image 1 of 1
    • Remove the cover by pulling it up and off.
    Ask FixBot
  6. Nokia E61i Headset Jack Replacement, Display: step 6, image 1 of 2 Nokia E61i Headset Jack Replacement, Display: step 6, image 2 of 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon, disconnecting contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
    Ask FixBot
  7. Nokia E61i Headset Jack Replacement: step 7, image 1 of 2 Nokia E61i Headset Jack Replacement: step 7, image 2 of 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
    Ask FixBot
  8. Nokia E61i Headset Jack Replacement, Motherboard: step 8, image 1 of 3 Nokia E61i Headset Jack Replacement, Motherboard: step 8, image 2 of 3 Nokia E61i Headset Jack Replacement, Motherboard: step 8, image 3 of 3
    • Pull the green motherboard from the back casing.
    Ask FixBot
  9. Nokia E61i Headset Jack Replacement, Connector Housing: step 9, image 1 of 1
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
    Ask FixBot
  10. Nokia E61i Headset Jack Replacement, Headset Jack: step 10, image 1 of 1
    • Remove the headset jack from the housing by pulling it up.
    Ask FixBot
Christopher Patton
208 Reputation
12 Guides authored
Cal Poly, Team 9-63, Walters Spring 2011 Member of Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 46
All Time: 3,095
