Up to 20% off select tools
Nokia E61i Display Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
99
All Time:
4,372
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the Nokia E61i screen.
    1. Nokia E61i Display Replacement, Battery: step 1, image 1 of 2 Nokia E61i Display Replacement, Battery: step 1, image 2 of 2
      • First, gather all necessary tools.
      • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
      • Slide the back cover downwards off of the phone while pressing down on the tab.
      Ask FixBot
    2. Nokia E61i Display Replacement: step 2, image 1 of 1
      • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
      Ask FixBot
    3. Nokia E61i Display Replacement: step 3, image 1 of 1
      • Lift the battery out using your finger.
      • The E61i uses a Nokia BP-4L standard battery.
      Ask FixBot
    1. Nokia E61i Display Replacement, Front Cover: step 4, image 1 of 2 Nokia E61i Display Replacement, Front Cover: step 4, image 2 of 2
      • To remove the top of the back cover, pry the sides and pop it off.
      • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
      Ask FixBot
    2. Nokia E61i Display Replacement: step 5, image 1 of 1
      • Remove the cover by pulling it up and off.
      Ask FixBot
    1. Nokia E61i Display Replacement, Display: step 6, image 1 of 2 Nokia E61i Display Replacement, Display: step 6, image 2 of 2
      • Take off the casing and keyboard.
      • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
      • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
      • Lift the ribbon, disconnecting contact with the motherboard.
      • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
      Ask FixBot
    2. Nokia E61i Display Replacement: step 7, image 1 of 2 Nokia E61i Display Replacement: step 7, image 2 of 2
      • Gently pull the screen off of the phone.
      • Be sure not to rip the sticker that connects the display and the motherboard.
      • Pull the silver case off to completely free the cracked or damaged screen.
      Ask FixBot
3 other people completed this guide.
Author
with
Christopher Patton
208 Reputation
12 Guides authored
Cal Poly, Team 9-63, Walters Spring 2011 Member of Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 99
All Time: 4,372
