Nokia Classic 2600c-2b Display Screen Replacement
    1. Nokia Classic 2600c-2b Display Screen Replacement, Replacing Display Screen: step 1, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement, Replacing Display Screen: step 1, image 2 of 2
      • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
      • Pull the phone apart from the bottom, keeping the button pressed down.
      • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
      Ask FixBot
    2. Nokia Classic 2600c-2b Display Screen Replacement: step 2, image 1 of 1
      • Remove the back cover to expose the battery.
      Ask FixBot
    3. Nokia Classic 2600c-2b Display Screen Replacement: step 3, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 3, image 2 of 2
      • Place a finger or plastic opening tool in the gap between the battery and the phone.
      • Gently lift the battery out.
      Ask FixBot
    4. Nokia Classic 2600c-2b Display Screen Replacement: step 4, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 4, image 2 of 2
      • Locate the plastic latches on the left and right sides of the phone.
      • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
      • CAUTION! Some force is required.
      Ask FixBot
    5. Nokia Classic 2600c-2b Display Screen Replacement: step 5, image 1 of 1
      • Remove the faceplate with the number pad attached.
      Ask FixBot
    6. Nokia Classic 2600c-2b Display Screen Replacement: step 6, image 1 of 1
      • Turn the faceplate so the number pad faces downward.
      • Lift the number pad out of the faceplate.
      Ask FixBot
    7. Nokia Classic 2600c-2b Display Screen Replacement: step 7, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 7, image 2 of 2
      • Locate the six screws positions along the edges of the motherboard.
      • Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
      • CAUTION! Place the screws in a secure location.
      Ask FixBot
    8. Nokia Classic 2600c-2b Display Screen Replacement: step 8, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 8, image 2 of 2
      • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
      • Lift the black latch attaching the tape to the motherboard.
      • Gently pull the tape out of the latch slot to remove the metal display.
      Ask FixBot
    9. Nokia Classic 2600c-2b Display Screen Replacement: step 9, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 9, image 2 of 2
      • Using the plastic opening tool, gently pry off the motherboard from the plastic shell.
      • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
      Ask FixBot
    10. Nokia Classic 2600c-2b Display Screen Replacement: step 10, image 1 of 1
      • Gently pull the orange ribbon tape up to remove the display.
      • Replace display screen.
      • Follow the instructions in reverse order to reassemble the phone.
      Ask FixBot
3 other people completed this guide.
Ian VanZandt
699 Reputation
5 Guides authored
3 Guide Comments
Pretty accurate, nice guide! Easily repaired and it works!
Dominik Fryč - Reply Share
Where can I find the screen?
jackie fincher - Reply Share
Perfect guide! But Where can i get original components??
Navin Singh - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,420
