Up to 20% off select tools
Nokia C2-01 Dissasembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
121
All Time:
546
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 6 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
I apologize for the grainy photos, I don't have a very good camera.
    1. Nokia C2-01 Dissasembly, Nokia C2-01: step 1, image 1 of 3 Nokia C2-01 Dissasembly, Nokia C2-01: step 1, image 2 of 3 Nokia C2-01 Dissasembly, Nokia C2-01: step 1, image 3 of 3
      • Remove back cover by sliding downwards.
      • Remove battery and sim card (if applicable).
      Ask FixBot
    2. Nokia C2-01 Dissasembly: step 2, image 1 of 1
      • Remove two 5mm-long screws on the left and right using a T6 Torx screwdriver.
      Ask FixBot
    3. Nokia C2-01 Dissasembly, Remove front cover: step 3, image 1 of 1
      • Flip phone over to front.
      • Insert opening pick underneath headphone jack and pry around edge of phone until front cover pops off.
      Ask FixBot
    4. Nokia C2-01 Dissasembly: step 4, image 1 of 2 Nokia C2-01 Dissasembly: step 4, image 2 of 2
      • Remove four 5mm-long screws in the corners of the motherboard using a Torx T6 screwdriver.
      • Be careful not to touch the LCD screen!
      Ask FixBot
    5. Nokia C2-01 Dissasembly, Seperate the motherboard: step 5, image 1 of 3 Nokia C2-01 Dissasembly, Seperate the motherboard: step 5, image 2 of 3 Nokia C2-01 Dissasembly, Seperate the motherboard: step 5, image 3 of 3
      • Pull one plastic clip out of the way and gently lift and pull the motherboard out of the housing.
      Ask FixBot
    6. Nokia C2-01 Dissasembly, Remove Screen Bracket: step 6, image 1 of 3 Nokia C2-01 Dissasembly, Remove Screen Bracket: step 6, image 2 of 3 Nokia C2-01 Dissasembly, Remove Screen Bracket: step 6, image 3 of 3
      • Flip phone over and use Spudger to move metal clips out of the way.
      • Flip phone back over and remove metal screen housing.
      Ask FixBot
    7. Nokia C2-01 Dissasembly, Remove screen: step 7, image 1 of 2 Nokia C2-01 Dissasembly, Remove screen: step 7, image 2 of 2
      • Use Spudger to lift the screen cable, and remove screen.
      Ask FixBot
Finish Line
Author
with
Jonathan Vacek
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 121
All Time: 546
