Up to 20% off select tools
Nokia Asha 201 Keyboard Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
14
Past 30 Days:
58
All Time:
636
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the faulty or unresponsive keyboard on your Nokia Asha 201.
A properly functioning keyboard is a crucial component of your phone, as it allows you to type messages, type phone numbers to make phone calls, and search on the internet. If your keyboard is missing keys or not responding how it should be, a keyboard replacement is necessary to restore the device to functioning correctly.
Before beginning the replacement, try cleaning the keyboard to ensure debris or a sticky substance is not the issue. You may even benefit from a second opinion before proceeding. Once you have confirmed the problem, follow this guide to replace the keyboard safely and efficiently.
Power off your phone and remove the battery before starting this replacement. Gather all the necessary tools, including a small screwdriver to remove the screws on the phone and an iFixit opening tool. Utilizing these tools ensures you avoid damaging the device when disassembling it.
Handle all components of the phone with care, and make sure to keep track of all the parts, especially the screws, to ensure a smooth reassembly.
After following this essential step-by-step guide, your Nokia Asha 201 keyboard will return to new.
    1. Nokia Asha 201 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Remove back cover of device by pressing firmly and sliding the cover off.
      Ask FixBot
    2. Nokia Asha 201 Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    3. Nokia Asha 201 Keyboard Replacement: step 3, image 1 of 1
      • Remove the two screws found on the left and right side of the phone.
      Ask FixBot
    4. Nokia Asha 201 Keyboard Replacement: step 4, image 1 of 1
      • Remove the front case using the iFixit opening tool.
      Ask FixBot
    5. Nokia Asha 201 Keyboard Replacement: step 5, image 1 of 1
      • Remove the keyboard.
      Ask FixBot
Author
with
Paige Routh
139 Reputation
1 Guide authored
USF Tampa, Team S1-G3, Leahy Fall 2019 Member of USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 58
All Time: 636
