Up to 20% off select tools
Nokia 8290 Microphone Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
19
All Time:
869
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Installing a new microphone may be necessary if those receiving calls from you are unable to hear you. Installation should only be done as a last resort, after trying all other possible solutions as listed in the Nokia 8290 Troubleshooting Guide. Installation requires no prior knowledge of mobile phone microphones.
    1. Nokia 8290 Microphone Replacement, Front Cover: step 1, image 1 of 3 Nokia 8290 Microphone Replacement, Front Cover: step 1, image 2 of 3 Nokia 8290 Microphone Replacement, Front Cover: step 1, image 3 of 3
      • Locate the small button on the top of the phone.
      • Depress the button.
      • With your other hand, pull the front cover away from the phone.
      Ask FixBot
    1. Nokia 8290 Microphone Replacement, Circuit Board: step 2, image 1 of 3 Nokia 8290 Microphone Replacement, Circuit Board: step 2, image 2 of 3 Nokia 8290 Microphone Replacement, Circuit Board: step 2, image 3 of 3
      • Remove all six 5.3 mm long T6 screws.
      • Remove the circuit board/faceplate sub-assembly from the back of the phone.
      • Take care to place screws in a safe location.
      Ask FixBot
    2. Nokia 8290 Microphone Replacement: step 3, image 1 of 3 Nokia 8290 Microphone Replacement: step 3, image 2 of 3 Nokia 8290 Microphone Replacement: step 3, image 3 of 3
      • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
      • Rotate the faceplate away from the circuit board.
      • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
      Ask FixBot
    1. Nokia 8290 Microphone Replacement, Microphone: step 4, image 1 of 3 Nokia 8290 Microphone Replacement, Microphone: step 4, image 2 of 3 Nokia 8290 Microphone Replacement, Microphone: step 4, image 3 of 3
      • Use the spudger to peel back the top-left corner of the white adhesive film. This can be done by working the spudger back and forth underneath the film.
      Ask FixBot
    2. Nokia 8290 Microphone Replacement: step 5, image 1 of 3 Nokia 8290 Microphone Replacement: step 5, image 2 of 3 Nokia 8290 Microphone Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Continue to peel the film back until you can see the microphone.
      • Use tweezers to remove the microphone.
      Ask FixBot
Author
with
Parker Niebauer
7 Reputation
6 Guides authored
Clemson, Team 15-3, Benson Fall 2012 Member of Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 869
