Nokia 8290 Circuit Board Replacement
    1. Nokia 8290 Circuit Board Replacement, Front Cover: step 1, image 1 of 3 Nokia 8290 Circuit Board Replacement, Front Cover: step 1, image 2 of 3 Nokia 8290 Circuit Board Replacement, Front Cover: step 1, image 3 of 3
      • Locate the small button on the top of the phone.
      • Depress the button.
      • With your other hand, pull the front cover away from the phone.
      Ask FixBot
    1. Nokia 8290 Circuit Board Replacement, Circuit Board: step 2, image 1 of 3 Nokia 8290 Circuit Board Replacement, Circuit Board: step 2, image 2 of 3 Nokia 8290 Circuit Board Replacement, Circuit Board: step 2, image 3 of 3
      • Remove all six 5.3 mm long T6 screws.
      • Remove the circuit board/faceplate sub-assembly from the back of the phone.
      • Take care to place screws in a safe location.
      Ask FixBot
    2. Nokia 8290 Circuit Board Replacement: step 3, image 1 of 3 Nokia 8290 Circuit Board Replacement: step 3, image 2 of 3 Nokia 8290 Circuit Board Replacement: step 3, image 3 of 3
      • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
      • Rotate the faceplate away from the circuit board.
      • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
      Ask FixBot
Parker Niebauer
7 Reputation
6 Guides authored
Clemson, Team 15-3, Benson Fall 2012 Member of Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 830
