Nokia 8290 Antenna Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
93
All Time:
1,098
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Installing a new antenna may be necessary if you are having trouble sending and receiving calls. Installation should only be done as a last resort, after trying all other possible solutions as listed in the Nokia 8290 Troubleshooting Guide. Installation requires no prior knowledge of mobile phone antennas.
Tools
    1. Nokia 8290 Antenna Replacement, Front Cover: step 1, image 1 of 3 Nokia 8290 Antenna Replacement, Front Cover: step 1, image 2 of 3 Nokia 8290 Antenna Replacement, Front Cover: step 1, image 3 of 3
      • Locate the small button on the top of the phone.
      • Depress the button.
      • With your other hand, pull the front cover away from the phone.
      Ask FixBot
    1. Nokia 8290 Antenna Replacement, Antenna: step 2, image 1 of 3 Nokia 8290 Antenna Replacement, Antenna: step 2, image 2 of 3 Nokia 8290 Antenna Replacement, Antenna: step 2, image 3 of 3
      • Remove all six 5.3 mm long T6 screws.
      • Remove the circuit board/faceplate sub-assembly from the back of the phone.
      • Take care to place screws in a safe location.
      Ask FixBot
    2. Nokia 8290 Antenna Replacement: step 3, image 1 of 3 Nokia 8290 Antenna Replacement: step 3, image 2 of 3 Nokia 8290 Antenna Replacement: step 3, image 3 of 3
      • After removing the circuit board/faceplate sub-assembly, locate the antenna.
      • Remove the antenna by prying it out with your fingers or a prying tool. It may help to turn the back portion of the phone over to allow the antenna to fall away.
      Ask FixBot
Austin Culberson
87 Reputation
5 Guides authored
Clemson, Team 15-3, Benson Fall 2012 Member of Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 93
All Time: 1,098
