Nokia 8265 Logic Board Replacement
    1. Nokia 8265 Logic Board Replacement, Logic Board: step 1, image 1 of 1
      • Start by removing the face plate of the phone with a plastic tool.
      • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
      Ask FixBot
    2. Nokia 8265 Logic Board Replacement: step 2, image 1 of 1
      • Once the face plate is off, you will have exposed the keypad.
      Ask FixBot
    3. Nokia 8265 Logic Board Replacement: step 3, image 1 of 1
      • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
      Ask FixBot
    4. Nokia 8265 Logic Board Replacement: step 4, image 1 of 1
      • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
      • Make sure to remember what screw goes where.
      Ask FixBot
    5. Nokia 8265 Logic Board Replacement: step 5, image 1 of 1
      • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
      • The screen section will be able to be removed after Step 4 is finished.
      Ask FixBot
    6. Nokia 8265 Logic Board Replacement: step 6, image 1 of 1
      • Be careful when removing the Logic Board from the body, lifting it with fingers on both sides to prevent damage of the Logic Board.
      • Separate the Logic Board from the main body of the device.
      Ask FixBot
    7. Nokia 8265 Logic Board Replacement: step 7, image 1 of 1
      • Insert in the replacement Logic Board, setting the Logic Board carefully back into place.
      Ask FixBot
    8. Nokia 8265 Logic Board Replacement: step 8, image 1 of 1
      • Set the screen carefully over the body of the phone, avoiding any sliding on the Logic board
      Ask FixBot
    9. Nokia 8265 Logic Board Replacement: step 9, image 1 of 1
      • Replace screws in the corresponding slots, tightening them till they are not loose.
      Ask FixBot
    10. Nokia 8265 Logic Board Replacement: step 10, image 1 of 1
      • Replace keypad onto the device
      Ask FixBot
    11. Nokia 8265 Logic Board Replacement: step 11, image 1 of 1
      • Lastly, you can place the cover onto the phone. You will know when it is in place if you hear a click after placing it in.
      Ask FixBot
Finish Line
Jack
22 Reputation
4 Guides authored
SUNY Cortland, Team 1-1, Getto Spring 2012 Member of SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 1,583
