Up to 20% off select tools
Nokia 8265 Keypad Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
43
All Time:
1,332
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
Your Nokia 8265 keypad may eventually become sticky or unresponsive as a result of spills, debris buildup, or normal wear and tear. Thankfully, changing or cleaning the keypad is a simple procedure that requires minimal tools. The keypad of your Nokia 8265 can be removed, cleaned, and replaced with the help of these instructions.
Follow the instructions to replace the keypad for your Nokia 8265 phone. Before you begin, make sure to turn off your phone and unplug it from the charger.
    1. Nokia 8265 Keypad Replacement, Keypad: step 1, image 1 of 1
      • Using a plastic opening tool, wedge the tip of the tool into the side of the phone's faceplate
      • To pry open, wiggle/twist the tip of the tool, until faceplate pops up.
      Ask FixBot
    2. Nokia 8265 Keypad Replacement: step 2, image 1 of 1
      • Once popped off, remove the faceplate entirely, exposing the keypad.
      Ask FixBot
    3. Nokia 8265 Keypad Replacement: step 3, image 1 of 1
      • You can pick up the keypad with ease, as it is not attached to the phone itself.
      Ask FixBot
    4. Nokia 8265 Keypad Replacement: step 4, image 1 of 1
      • To clean keypad if it is not functioning properly, use a cloth to wipe away any spills, or water damage
      Ask FixBot
If cleaning off keypad does not work, insert your new keypad, and follow steps in reverse order to reassemble your device.
Author
with
Jack
22 Reputation
4 Guides authored
SUNY Cortland, Team 1-1, Getto Spring 2012 Member of SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 43
All Time: 1,332
