This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓In this guide, we will show you how to safely replace the Nokia 6630 battery. The operation is simple and only takes a few minutes. Before you start, ensure you are using a compatible battery and working on a clean, stable, and well-lit surface.
Completely power off the Nokia 6630 before you begin the replacement. If the phone is connected to a charger, disconnect the cable.
Turn the phone over with the display facing down. Locate the rear cover latch, then press or slide the release mechanism and gently remove the cover.
Lift the battery using the pull tab or the recess on the edge.
Place the new battery into the recess, making sure it is oriented correctly. The metal contacts on the battery must align with the corresponding contacts in the phone.
