Nokia 6590i Speaker Replacement
    1. Nokia 6590i Speaker Replacement, Battery: step 1, image 1 of 2 Nokia 6590i Speaker Replacement, Battery: step 1, image 2 of 2
      • Press the button on the bottom of the rear cover.
      • Keep the button pressed while pulling the cover downward to remove the back cover.
      • Lift the cover off.
      Ask FixBot
    2. Nokia 6590i Speaker Replacement: step 2, image 1 of 1
      • Push the battery down from the top and pull it out.
      Ask FixBot
    1. Nokia 6590i Speaker Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: step 3, image 1 of 1
      • Grip the front cover from the bottom.
      Ask FixBot
    2. Nokia 6590i Speaker Replacement: step 4, image 1 of 1
      • Lift the front cover off.
      Ask FixBot
    3. Nokia 6590i Speaker Replacement: step 5, image 1 of 1
      • Remove the six screws using a T6 torx screwdriver.
      Ask FixBot
    4. Nokia 6590i Speaker Replacement: step 6, image 1 of 1
      • Insert spudger along edge of assembly and gently lift assembly away from case
      Ask FixBot
    5. Nokia 6590i Speaker Replacement: step 7, image 1 of 1
      • Remove assembly from phone
      Ask FixBot
    1. Nokia 6590i Speaker Replacement, Speaker: step 8, image 1 of 1
      • Flip assembly over
      Ask FixBot
    2. Nokia 6590i Speaker Replacement: step 9, image 1 of 1
      • Locate speaker on the back of the assembly.
      Ask FixBot
    3. Nokia 6590i Speaker Replacement: step 10, image 1 of 1
      • Insert spudger under upper left side of speaker and gently lift to remove
      Ask FixBot
    4. Nokia 6590i Speaker Replacement: step 11, image 1 of 1
      • Remove speaker.
      Ask FixBot
Colby Leslie
13 Reputation
7 Guides authored
Cal Poly, Team 22-3, Maness Fall 2010 Member of Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 1,068
