Nokia 6560 keypad replacement or cleaning
  1. Nokia 6560 keypad replacement or cleaning, Battery: step 1, image 1 of 2 Nokia 6560 keypad replacement or cleaning, Battery: step 1, image 2 of 2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
    Ask FixBot
  2. Nokia 6560 keypad replacement or cleaning: step 2, image 1 of 2 Nokia 6560 keypad replacement or cleaning: step 2, image 2 of 2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
    Ask FixBot
  3. Nokia 6560 keypad replacement or cleaning, Keypad: step 3, image 1 of 2 Nokia 6560 keypad replacement or cleaning, Keypad: step 3, image 2 of 2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
    Ask FixBot
  4. Nokia 6560 keypad replacement or cleaning: step 4, image 1 of 2 Nokia 6560 keypad replacement or cleaning: step 4, image 2 of 2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
    Ask FixBot
3 other people completed this guide.
Tim Bergmann
35 Reputation
4 Guides authored
Cal Poly, Team 3-17, Maness Winter 2010 Member of Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 2,519
