Nokia 6350-1b Display Screen Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
40
All Time:
2,430
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to replace the display screen of the Nokia 6350-1b cellphone.
Tools
    1. Nokia 6350-1b Display Screen Replacement, Display Screen: step 1, image 1 of 2 Nokia 6350-1b Display Screen Replacement, Display Screen: step 1, image 2 of 2
      • Using an iFixit opening tool, separate the plastic frame and the rest of the phone.
      • Move the opening tool along the frame, unlocking all of the locks that keep the frame in place.
      • Remove the plastic frame and set aside.
      • Be careful not to pry too hard; doing so could crack the plastic frame.
      Ask FixBot
    2. Nokia 6350-1b Display Screen Replacement: step 2, image 1 of 1
      • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
      • Using an opening tool, pry between the screen cover (top left) and the phone frame (top right).
      • To separate, unlock the various groove-like locks on all four sides of the phone.
      • Carefully remove the screen cover (top left) to reveal the logic board (bottom).
      • Keep track of the four small screws. They will be needed to put the phone back together.
      Ask FixBot
    3. Nokia 6350-1b Display Screen Replacement: step 3, image 1 of 1
      • Disconnect the flex cable from the logic board.
      • Disconnect the damaged LCD display screen and remove from the device.
      • Remember to dispose of the damaged LCD display screen responsibly; do not throw away with household trash, as electronic parts are considered household hazardous waste (HHW).
      Ask FixBot
    4. Nokia 6350-1b Display Screen Replacement: step 4, image 1 of 1
      • Connect the new LCD display screen to the phone.
      • Reconnect the logic board (bottom right) to the flex cable (gold tab).
      Ask FixBot
    5. Nokia 6350-1b Display Screen Replacement: step 5, image 1 of 1
      • Using the T-5 screwdriver, screw the four screws back into the phone.
      Ask FixBot
    6. Nokia 6350-1b Display Screen Replacement: step 6, image 1 of 1
      • Place the cover back on the device so that it is in the correct position to be reinstalled. Use the opening tool from earlier to direct the cover with precision.
      • Press gently on the cover so that it snaps back into place.
      Ask FixBot
Anna
25 Reputation
2 Guides authored
SUNY Cortland, Team 1-2, Getto Spring 2012 Member of SUNY Cortland, Team 1-2, Getto Spring 2012
SUNYCORT-GETTO-S12S1G2
2 Members
48 Guides authored
1 Guide Comment
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
Annemarie Heineman - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 40
All Time: 2,430
