Up to 20% off select tools
Nokia 6310i Keypad Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
100
All Time:
6,422
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows the procedures to replace a new keypad and clean metal button contacts for Nokia 6310i cell phone. Refer to the guides for removing the battery and separating the case from the motherboard.
    1. Nokia 6310i Keypad Replacement, Battery: step 1, image 1 of 2 Nokia 6310i Keypad Replacement, Battery: step 1, image 2 of 2
      • Press and hold the battery release button and slide the battery away from the Nokia logo
      Ask FixBot
    1. Nokia 6310i Keypad Replacement, SIM card: step 2, image 1 of 3 Nokia 6310i Keypad Replacement, SIM card: step 2, image 2 of 3 Nokia 6310i Keypad Replacement, SIM card: step 2, image 3 of 3
      • Slide the SIM card lock away from the SIM card.
      • The SIM card pops out. Remove the SIM card.
      Ask FixBot
    1. Nokia 6310i Keypad Replacement, Back Cover: step 3, image 1 of 1
      • Unscrew and remove the four T6 Torx screws.
      Ask FixBot
    2. Nokia 6310i Keypad Replacement: step 4, image 1 of 3 Nokia 6310i Keypad Replacement: step 4, image 2 of 3 Nokia 6310i Keypad Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
      Ask FixBot
    3. Nokia 6310i Keypad Replacement: step 5, image 1 of 3 Nokia 6310i Keypad Replacement: step 5, image 2 of 3 Nokia 6310i Keypad Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to separate the top part of the backplate.
      • The plastic clips at the top require slightly more force to separate.
      Ask FixBot
    1. Nokia 6310i Keypad Replacement, Antenna: step 6, image 1 of 2 Nokia 6310i Keypad Replacement, Antenna: step 6, image 2 of 2
      • Remove the screw holding the antenna to the circuit board.
      • Carefully lift off the antenna from the circuit board.
      Ask FixBot
    1. Nokia 6310i Keypad Replacement, Motherboard: step 7, image 1 of 1
      • Lift off the motherboard from the faceplate.
      Ask FixBot
    1. Nokia 6310i Keypad Replacement, Keypad: step 8, image 1 of 2 Nokia 6310i Keypad Replacement, Keypad: step 8, image 2 of 2
      • Remove the plastic keypad from the faceplate.
      Ask FixBot
Author
with
Ka Siu
84 Reputation
1 Guide authored
Cal Poly, Team 14-41, Forte Fall 2010 Member of Cal Poly, Team 14-41, Forte Fall 2010
CPSU-FORTE-F10S14G41
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 100
All Time: 6,422
